Special tool to replace output shaft seals? - Defender Source
Old July 28th, 2006, 12:03 AM
Hey guys - the manual says I need a special tool to refit the t-case output shaft seals. What does this thing look like and what does it do? Do I need one? Is there a generic equivalent (like something available at Napa)? I need to do this job and want to not f it up.
Old July 28th, 2006, 09:13 AM
Monkeyboy
Guest
Posts: n/a
I borrowed one from the local dealer. It's just a stepped ring that (a) insures "square" placement of the seal and (b) provides the appropriate, what 4mm, recess into the case.
It's been last summer since I did this, so don't hold me to the 4mm number - that sounds like the hub seal number now that I think of it.
KAA
Old July 28th, 2006, 09:44 PM
redrover
Guest
Posts: n/a
Hey jim, I just posted a question and then saw your post. You dont happen to know if the seal is the same part as a pinion seal? Also you can use a rift and work the seal in evenly just as well. be sure to pre oil it. Also what were you doing to TC? My TC started leaking today after a great day on the trail . I have a extra pinion seal but the steelership just closed and am sol if they are different. Thanks JP
Jim can you post the part number of the seal yopu have? Thanks JP
Old August 2nd, 2006, 08:58 PM
I replaced my rear output seal a while ago without problem and I did not have any tool, come to think of it so did Jimmy. The trick is getting the old seal out! I used a 1/4" (or so) Allen key sticking the short end under the seal and using the long end as leverage to pry it out, worked like a charm!
Old August 2nd, 2006, 09:03 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
just whacked mine in, no problem
3rd low and BOOT IT
Old August 2nd, 2006, 10:03 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I left mine out....
Old August 2nd, 2006, 10:15 PM
Originally Posted by Bowtracer
I left mine out....
Yes, but my tcase leaks like a sieve from the front output shaft - I'm trying to stop this!
Old August 2nd, 2006, 10:43 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
JK jim
Old August 3rd, 2006, 12:15 AM
snark
Old August 3rd, 2006, 10:23 AM
It is just a regular shaft seal. No different than any other. If you are capable of installing a shaft seal without hurting yourself, this is no different.
ac, seals
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
T-Case output shaft help WhiteD90 Defender Technical Discussions 1 August 6th, 2004 10:13 AM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
