speakers in sw doors - Page 2 - Defender Source
Old April 13th, 2012, 10:21 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Rovers North
Old April 13th, 2012, 10:36 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks, I'll try them tomorrow
Old April 14th, 2012, 07:52 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Originally Posted by James Pierce View Post
Guru? Hmmm... The NAS SW speaker came in the door. You will need the spacer that came with the NAS door panel to make them fit. I'm running JL Audio 6 / 1 components in the door without issue. The crossover is also hidden in there as well as a layer of Closed Cell Foam Decoupler and a layer of Mass Load Vinyl. Sounds pretty good.
Hi James
Did you buy component 6 1/2" speakers ?
Would you have any more pics of your system ?
Looks like a perfect setup.
Thank you.
Campbell:
To bad JL doesn't offer these for the 6 1/2 .....
http://store.earmarkcaraudio.com/Xca...cat=254&page=1
Billet aluminum.....and I would imagine offer better protection. Maybe one of our fourmite fab gurus could make something up....it seems like the JL Audios are the favorite.
Rob
Old April 15th, 2012, 07:31 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anybody have any pictures of how the wires are run from the door to the body?
Also was wondering if any of the screws go into metal? or are the just attached to the door panel.
Old April 15th, 2012, 07:56 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Tom, You will need the little rubber tube that goes between the door and bulkhead. You can see it in one of the pic's I posted ^^^
Screws go into the card. There is a little clip nut that goes over the card where the screws hit.
Old April 15th, 2012, 08:18 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great Thanks, I just have to find 2 of those little rubber tubes.
Old April 15th, 2012, 08:27 AM
James Pierce
James Pierce Jr.
I purchased new ones from RN. They weren't very expensive. RN had the new speaker wire pig tail with the factory end that attaches to the harness inside the bulkhead too. I could hunt down the PN tomorrow if you need.
Old April 15th, 2012, 08:59 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Hopefully I should be able to find them, I'll let you know if I can't.
Old April 15th, 2012, 09:39 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Maybe this will help?
http://www.defendersource.com/forum/...hlight=speaker
Tom,
You have a TD5 style bulkhead and doors correct? If you find the proper rubber part that goes between the door and bulkhead let me know the part number and where since I also need that part
Old April 15th, 2012, 12:17 PM
I believe it's called a dongle
Old April 17th, 2012, 04:54 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Talked to Less at Rovers North and the speaker spacer/mounts are $68 a piece
Old April 17th, 2012, 04:56 PM
FYI. The LaSalle door cards are fiberglass and have a raised section specifically for speakers to be mounted.
Old April 17th, 2012, 05:04 PM
I could have sworn I saw someone either made (or had them made) out of aluminum. They were pretty nice!
Old April 17th, 2012, 11:49 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I am going to keep searching, I have a message out to Justin to see if one of his super secret sources has some kind of aftermarket set up.
door, speakers
New Style SW Doors bjp Defender Technical Discussions 39 December 26th, 2009 03:04 PM
trade SW doors for ST doors ron For Sale - Parts 13 October 17th, 2008 11:33 AM
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
ST doors an SW rover4x4 Defender Technical Discussions 6 October 6th, 2003 02:29 PM
