Speaker wire routing to front doors - Defender Source
Old December 22nd, 2009, 12:32 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Installing a radio and speakers in my 1984 and trying to figure out how to run the speakers wires to the front doors.
I found the following post from Jim C that talk about the routing of the wires but I am having a hard time visualizing how the wires get from the engine bay into the doors.
http://www.defendersource.com/forum/...0&postcount=11
Does anyone have a picture of how they are routed from the engine compartment to the doors?
Old December 22nd, 2009, 10:51 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am stealing this picture from Jim C's rebuild thread as it shows the bulkhead without the fenders installed. Is the hole in the pictures the proper hole to route the speakers wires through?
If so does anyone have a picture of where the speaker wire comes out on the other side?
Old December 22nd, 2009, 10:58 AM
That's were Josh got a bit fast and loose drilling out the galv from the vents ... ;-)
Old December 22nd, 2009, 02:06 PM
Chaucer
Will
93 110 | 97 90
Dave, yes, that's where you run the speaker wires for the fron doors. Incidentally, that's the same wire run the dome light triggers use.
Old December 23rd, 2009, 12:00 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Found a picture of the inside of the bulkhead and thought I would post it here for future searches
FWIW my 1984 bulkhead does not have any of the holes show, and I am not looking to remove my fenders at the moment so I will have to find another way to route the wires
Old December 23rd, 2009, 10:05 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Dont want to hijack the thread, but where does the dome switch wire get voltage? That side of the dome light is dead and trying to hunt down where it ties into a 12v source.
Old December 29th, 2009, 06:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
THe switch side is the ground not the power supply
Legend in My Own Mind.
Old December 29th, 2009, 12:47 PM
dave
on my 109 I just drilled a small hole in the door pillars where I wanted the wires to come out. I ran the actual cable out through the bottom of the door pillar and clipped it to the back of the bulkhead outriggers inside a piece of corrugated split loom. where the wire comes out of the pillar I didn't have the proper LR part so i used a regular grommet and some more split loom. it looks ron good and does the job.
next time around I'll probably just find a different spot for the speakers.
door
Looking for SW front doors kellymoe Wanted 0 December 6th, 2004 11:44 PM
Front Speaker Grills RFA Wanted 3 September 2nd, 2004 03:50 PM
