Spark Plugs?? Please help. - Defender Source
Old May 15th, 2015, 11:54 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
While digging through the garage I came across a brand new/never used set of Bosch Platinum spark plugs. Plug number WR9DP.
Will these work for a 1997 D90 NAS 4.0? All research I've done says they work for 3.9 disco and 4.0 d90. Thanks!!
------ Follow up post added May 15th, 2015 10:59 AM ------
Oops!! There's a typo above! The research I've done says they fit 3.9 disco and 4.0 RR. No evidence they will work on 4.0 NAS D90
Old May 15th, 2015, 12:04 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Not sure. But I can't tell you how many times I've told people to stick with champion plugs and oem wires for our Defenders.
Old May 15th, 2015, 01:01 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Why champion plugs?
Old May 15th, 2015, 01:12 PM
rankar's Avatar
rankar
those are specified in the workshop manual. these engines are finicky as it is, so if you've got an oem setup then stay with what's outlined in the manual:
Champion RN11YCC
"incorrect grade of plugs may lead to piston overheating and engine failure."
So use above, apply anti-seize, torque to 15 lbs/ft, route wires correctly to avoid cross-firing, have a beer.
Old May 15th, 2015, 01:46 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
In all the rovers I have owned, all ways used the cheapest copper champion plugs with the best wires you can find.
These engines run just as good with a 1.50 dollar a plug agaist a 8 dollar a plug, just change every inspection time.
That's my 2 pence worth
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 15th, 2015, 04:17 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Champion or AutoLite coppers gapped to .050, with 8mm Kingsbourne wires.
Old May 15th, 2015, 06:08 PM
rankar's Avatar
rankar
why the wider gap? 0.035 to 0.040 is to spec in the manual. aren't you running a higher risk of misfirings?
Old May 16th, 2015, 11:25 AM
Ngk-bpr5ey
Good Spark, Bad Spark Big D Defender Technical Discussions 4 August 19th, 2008 09:43 AM
Which spark plugs? Hammertime Defender Technical Discussions 2 January 30th, 2008 10:15 PM
New spark plugs and wire problem ini88 Defender Technical Discussions 1 December 22nd, 2007 10:56 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
Spark plugs for a supercharged 4.0.. Tom Fitzgerald Defender Technical Discussions 0 May 10th, 2004 11:43 PM
