Spark plug recommendations - Defender Source
Old December 13th, 2005, 07:07 PM
tron's Avatar
tron
Thomas F
Recently Roverless
The guy at the dealership suggested Bosch. I have seen some posts about problems with the Platinum...any other suggestions?
Tom
Old December 13th, 2005, 07:23 PM
saber6's Avatar
saber6
gh
Hey Tom: I put in the Bosch 4 prong (sorry I don't know the terminology) but they work awesome, I really noticed a difference and I'm one to be hesitant when it comes to things like that. Nonetheless, great plug took me like 20 min to put in. Also, I recommend the MSD wires. gh
Old December 13th, 2005, 07:46 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I like NGK V-Power....good cheap basic plug that always works well. The only Bosch I would use would be the basic copper core plug...no wierd stuff.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 13th, 2005, 08:33 PM
Scott 9835
Scott Falter
95 D90
I would use the same plug rover does. I have found so many bad platinum and split fire plugs, that people wast there money on. Good plug wires are a very good upgrade. Use factory cap and rotor as well. I have found a lot of bad cheap aftermarkt caps and rotors, the cheap rotors seem to mess up and cause missfires and hard or no start.
Old December 13th, 2005, 11:57 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
NGK or Stock Land Rover which is Champion. I have never been impressed with anything BOSCH.
Tom
If it was Ken Parker who told you that (Land Rover Austin) .. I am going to have to give him a ring. He knows better than that! Basic BOSCH are *ok* IMHO, the really cheap/basic ones (.99 each). I would stay away from anything Platinum!
I bought the diamonds myself so I would not have to say thank you to anyone.
Old December 14th, 2005, 12:07 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
You have obviously not tried the Bosch washer and dryer.
I can wash my clothes with as little as 1.4 gal of water (full cycle) and the total annual electricity usage is about 1/4 of the average washer+dryer.
(Sorry for the threadjacking. I couldn't resist.)
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 14th, 2005, 12:15 AM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Talking
LOL! That was funny...OK let me re-word: BOSCH Automotive Products!
Old December 14th, 2005, 08:27 AM
I like the NGKs! Forget the exapesive Bosch plugs, anything that is platinum coated (or whatever it is) cannot be cleaned as the coating will be cleaned off the plug and then they become pretty much junk.
Umm, isn't the computer running your engine a BOSCH!
Old December 14th, 2005, 09:30 AM
tron's Avatar
tron
Thomas F
Recently Roverless
Thanks for the suggestions guys. Rover Chic, the guy at the Austin dealership was a hispanic guy who I have seen there plenty. I forget his name, but I think he may be the manager of the parts department. Sounds like NGK might be the way to go.
Old December 14th, 2005, 10:17 AM
Where do yall buy your plugs? the local part store?
Old December 14th, 2005, 10:23 AM
Troys
Troy Smith
1995 D90 SW
Anyone else run Champion Truck Plugs #4404? I run these in my Defender and Series vehicles and have had very good luck with them.
Troy
Old December 14th, 2005, 02:15 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Thank you for proving my point! LOL! I went through 7 Re-Man Bosch Alternators on my D1. It got to the point that I was able to swap it out in the parking lot at NAPA in less than 8 minutes in the freezing rain.
Old December 14th, 2005, 02:40 PM
Seven! WOW lol, I think I would have been on the look out for something different after 3. I run an Autozone Alt on the 4.0 with no problmems so far, but it only has about 1500 miles on it Don't you love working on your rover when the weather is crappy out!
Old December 15th, 2005, 02:52 PM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
NGK Iridium spark plugs are the best i think, expensive though
James
Old March 31st, 2006, 11:58 AM
What are they plugs suppose to be torqued to and also what anti sieze do you use on them? thanks
Old March 31st, 2006, 12:07 PM
I don't remember the tork, but do the oil filter trick, screw in until it is tight, then an extra 1/4 to 1/2 turn to snug up.
Prestone and Loctite make Anti Seize,
http://68.72.74.113/Lubricants.htm
I think someone may even make anti seize for spark plugs. I would just run down to the auto parts store and get whatever they have.
Old March 31st, 2006, 12:48 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
I actually have never used anit-sieze with Spark Plugs. Do you really need to?
Old March 31st, 2006, 02:22 PM
It helps to keep from stripping the threads. Specially when things get overtightened!
Old March 31st, 2006, 07:00 PM
thanks we have a copper based anti seize we use on our drills rods I might use some of that then
Stripped spark plug threads in the heads Hans Defender Technical Discussions 0 November 8th, 2009 07:41 AM
Spark Plug/ ignition wires mdmccallum Defender Technical Discussions 3 September 1st, 2005 11:48 AM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
Spark Plug Poll DJ Menasco Defender Technical Discussions 5 March 17th, 2004 07:12 AM
