Spare tire hood mount - Defender Source
Old April 13th, 2004, 12:25 AM
bd90
94 Arles Blue #1644
I talked to George at RDS and he said there are two diff kits to mount spares on the hood. One alloy and the other steel. Also stated that if the hood is alloy you have to buy the alloy kit and vice versa. Didn't think to ask why at the time so now is a good time. Why? He charges @ $250 for the alloy which I guess is okay but was wondering if steel would be cheaper and stronger even if it isn't alloy like I suspect my 94 hood is. Anybody got any idea why it would matter? THanks in advance.
Old April 13th, 2004, 12:36 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Never heard of such a thing. The bonnet is made of aluminum, and all of them I should think. The kit is a bunch of parts, none of which should or would be aluminum...
Here's what the parts look like...
Old April 13th, 2004, 09:08 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
I think what he means was one kit is for an alloy wheel and the other is for a steelie. If you have a spare alloy wheel, you wouldn't be able to fit it in a kit made for a steelie and vice versa. I did hear that before but never had any experiences with them. Price-wise shouldn't be a big difference (if any).
Glenn
Old April 13th, 2004, 12:01 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
I have an old-skool hood mounted spare on the CrewCab. Parts are series-esque and parts are pure 127 (pre-Defender).
There's an entire hood frame made out of steel that's very heavy guage. I removed it and had it galvanized, then reinstalled it. Then there's a 3-post thingie that comes up through the hood. Two of the posts are threaded inside for the series bolts to go through and clamp the wheel down with these funky square-S shaped clamps. I am using a tire/rim combo that is too wide, so I made a piece of flat-bar to span the inside of the rim which holds the tire down with the same bolts. The third post is long enough to stick through one of the lugnut holes, and has a hole in it for a small padlock.
My tire is too wide to use the padlock, it just barely clears the lugnut hole.
Michael Slade
www.tawayama.com
Old April 13th, 2004, 12:25 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Glenn is right, he meant that there are two different types of bonnet mount. One that works with steel wheels and one that works with the alloys. The steel one is less expensive, it is a simple design. I would not recommend putting the tire on there though. You can't see a damn thing, its hard on the hood, and believe it or not, it makes the 90 even less aerodynamic
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 13th, 2004, 11:40 PM
bd90
94 Arles Blue #1644
Thanks all for the advice. And thanks, David, for the vote no on the hood spare. That's the first negative thing I have heard about the arrangement. Anyone else have - or + to say about it. Wicks had one mounted at one time and if I remember correctly he liked it. Wicks, am I right? Anyway, currently my 90 is a third vehicle and so the aerodynamic problem is not an issue nor is the visibility. I basically want it for the overall look. I Also plan on switching to the black wheels so the kit for the steel wheels is for me. Thanks also, for clearing up the confusion on the alloy/steel kits.
I am curious about the weight on the hood. Any stories about that?
Old April 14th, 2004, 12:38 AM
wicks's Avatar
wicks
Wicks
Brian, the weight on the hood is not little, so the hood flexes when hitting bumps. I love having the setup, but don't use it often. Only when going on a long or nasty run where there's a remote possibility of needing two spares. It is designed as a military bolt-on component, and is not engineered perfectly. The earlier bonnets had stiffer frames, but the Defender hood was not designed as such, thus the flexing. I plan to reinforce mine at some point.
The aerodynamic thing is debatable. Mine is quiter (air) when tire on bonnet.
The visibility thing is less an issue if you run proper wheels (steel 6.5" or less) and standard size tires (7.50x16 or 225/85/16, etc).
Old April 14th, 2004, 03:55 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Brian, don't do it for the looks. Do it because you need to put it there.
I've had spares on the hoods of all my series LR's (a '66 88-inch, a '70 109, a '53 80-inch and now the CrewCab).
I've never had a problem with visibility, but I'm used to it.
Aerodynamics are the LAST thing you should be worrying about when putting the spare on the hood.
If you have a rear mount for the spare tire, use it. If you need 2 spares like Wicks said, then the hood mounted spare is a good reason to do that. I've never been on a run that needed 2 spares, but can see the wisdom in doing so. I take comfort in knowing that my trailer uses the same wheel/tire combo that the CC does, so essentially when I take the trailer I have 2 spares (one on the trailer).
Also, consider the extra weight on your front springs, which may already be overloaded or nearly so if you run a big bullbar/winch.
If you're going to run bigger tires, then you might want to see if you can find an earlier hood with the beefier hood-frame. Mine flexes even though it's the earlier beefier style.
DON'T do it just because it looks good. Can I say that enough?
EDIT: Also don't forget that the tire is HEAVY. Lifting the hood is made MUCH harder with the tire on there. I have smashed my thumb before when the hood came down on it unexpectedly (my hands were wet and the hood slipped out and WHAMO!).
Michael Slade
www.tawayama.com
Old April 14th, 2004, 04:06 AM
wicks's Avatar
wicks
Wicks
I am a little confused on the while look thing. I wouldn't buy a Defender if it didn't look like it does. One of the things that makes a landy look cool is the tire on the hood.
Old April 14th, 2004, 04:24 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
True. But, the reason they put the tire on the hood was because they didn't want to sacrifice room in the bed.
Originally the spare tire was bolted behind the center bulkhead in the cargo area. LR saw fit to offer a spare tire carrier on the hood and many took advantage of it.
Yeah, it's one of the things that makes a series or defender LR unique, but it wasn't done originally to make it 'look cool'.
It ends up 'looking cool' because of it's honest function IMO.
If you want to recreate that look on your truck simply because it does look cool, then that's well within your right to do so. Personally I think that's the wrong reason, but that's just me.
But, I do end up being the pot that calls the kettle black, because there are certain things on my own vehicles that have been done to aid in the 'look'.
I could have gotten by with an F-350 Crew Cab with a utility box on the back and done just fine on the safaris I run. BUT, I wanted 'the look', so I stuck with LR's.
That's kind of an extreme example, but given to show that I am aware of my own hypocracy. It's OK to be a hypocrite as long as you know you're being one.
Oh, another one that happened to me today. I had a wing-mounted shovel on the 109 SW I had. I put it there partly because I thought it would 'look cool', and partly because I thought it would be handy there.
On the CC I specifically have not put one there because I thought it would be a little too poseur-ish.
Today I actually NEEDED to have access to a shovel and couldn't get into the rear cargo box to get mine. I was thinking that this would have been the perfect time to have had a pick and shovel on the wings.
Now I'm reassesing that particular item.
So, even I am a bit wishy-washy in that regard.
Michael Slade
www.tawayama.com
Old April 14th, 2004, 04:53 AM
wicks's Avatar
wicks
Wicks
Put the pick and shovel on the bonnet - much better config. Leaves the wintops clear for tools, etc. (function!)
My series had the bonnet mount, the rear door mount, AND the interior mount. I loved tossing the spare all around as needed. Yehaw!
Old April 14th, 2004, 12:01 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Hey, take some pics of your shovel/pick setup on your hood. I want to see how they're mounted and what shovell/pick you have.
Michael Slade
www.tawayama.com
Old April 14th, 2004, 02:35 PM
wicks's Avatar
wicks
Wicks
All Genuine/M0D ingredients...
Old April 14th, 2004, 02:37 PM
wicks's Avatar
wicks
Wicks
And...
Old April 14th, 2004, 06:14 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Is that all stuff from Rovers North? I got the same shovel kit for my 109 and thought I could make a better one after getting the pieces, realizing how simple they were and how much they wanted to charge for them.
Michael Slade
www.tawayama.com
Old November 12th, 2017, 11:36 AM
mjones1700
Michael Jones
1990 Defender 90
Okay, this thread is a little dated, but I need to make a decision today. I have a 1990 90. The spare was mounted in the cargo area, which was a problem. I removed it. I live on an island, literally, and can live without carrying a spare at all (and have). However, today I have the bonnet in the house doing the final sound proofing underneath. I must decided if I put the Forerunner bonnet mount on or not. I had a series with a bonnet mount and did fine. But either I do a bonnet mount, buy a new spare gate for the rear or just live without a spare. If I were to travel any distance, I would just throw it in the cargo area. What's you opinion?
hood, mount, spare, spare tire, tire
hood spare mount GeoParth Wanted 3 March 9th, 2006 10:55 PM
hood mounted spare tire holder GeoParth Wanted 3 October 13th, 2005 07:07 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
spare tire mount bonnet Abrooks For Sale - Parts 14 April 30th, 2004 11:01 AM
