Spare Tire Hinge Replacement - Defender Source
Old July 13th, 2010, 03:01 PM
PDX Bolt
Tom Harbolt
1995 White D90 Soft Top
Has anyone used the spare tire hinge replacement kit from Atlantic British? If so, would you recommend it for reducing the rattling of the tailgate door?
Old July 13th, 2010, 03:17 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I just installed it. Photos here:
http://www.flickr.com/photos/defende...7624439349518/
The tire carrier rebuild kit definitely eliminated most of the squeeking but the door still creaks when I open it because of the door hinges. Those are a bit harder to find and I haven't located a set yet.
Be prepared to have to get medieval on the old bolts. My truck is not very rusty but those bots were still a bitch. It took a lot of impact wrenching, dead blow hammer banging and PB spraying to get them off. I had the rack media blasted and powder coated while I was at it. Also replaced all of the hardware with type 316 stainless steel kit from McMaster.
Old July 13th, 2010, 03:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
The bolts look nice but I wish they were stainless. Mark on the board has them. His truck is the cleanest 90 I have ever seen except for the replacement AB bolts. They rusted to shit quickly. No clue why
Old July 13th, 2010, 03:28 PM
Door hinge repair kits are $5 or less from every vendor. Reassemble the hinges with copper anti-sieze and they won't squeak.
Ron
Old July 13th, 2010, 03:33 PM
chris snell
Chris Snell
87 Ex-MOD 110
Stainless bolts would probably not withstand the force of a tire bouncing around on them. Stainless on the other hardware isn't as huge of a deal; there's at least 11 bolts holding the carrier to the door, but only three bolts holding the carrier together.
The AB bolts are not galvanized or zinc plated. I plan on treating them with rust converter and primer and then painting the heads with a q-tip. Not much I can do about the stuff inside the bushing. I smeared a lot of anti-seize on mine when I installed them.
Old July 13th, 2010, 03:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah just the heads rust quickly. I do like them. Wish someone sold factory looking ones for cheap
Old July 13th, 2010, 06:15 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Chris, that cleaned up nice. Mine is showing some signs of rust and want to get it taken care of before winter hits. Are the bolts generic enough to source better replacements from mcmaster?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 14th, 2010, 12:29 AM
chris snell
Chris Snell
87 Ex-MOD 110
Daniel, they are just generic shoulder bolts and some bronze sleeve bearings. Definitely could be sourced from McMaster. Wish I had measured them before I installed them. I see some stainless steel shoulder bolts available. Who knows, maybe it would be strong enough. Maybe somebody here has an uninstalled set and could get some dimensions. I'm not about to pull mine out again.
Old July 19th, 2010, 06:16 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I searches the AB site for a rebuild kit for the tire carrier and found everything but! What is out there?
My tire carrier is at that stage where if it goes another winter, it's going to be twice as bad as it is now.
Old July 19th, 2010, 08:18 PM
Here is the AB link,
http://www.roverparts.com/Parts/8987.cfm
But you can buy them yourself too
http://www.defendersource.com/forum/...d.php?p=231615
ac, spare, spare tire, tire
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
Spare Tire Cover Weaver Wanted 0 August 25th, 2004 04:54 PM
defender 110 spare tire insert mpodgorski For Sale - Parts 7 July 7th, 2004 10:47 AM
Safari Gard spare tire carrier Cyborg Wanted 0 July 4th, 2004 07:39 AM
