Spacers and alloy wheels - Defender Source
Old September 10th, 2016, 11:55 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
I put terra firma spacers on a few months ago. Because it shifts the hub bolts over (using the old bolts to mount the spacers), the nuts on the hub rub into the alloy part of the inside wheel. The wheels (deep dish) have a space for these nuts when mounted without spacers, but with the new bolt location with the spacers, the nut now rubs into the alloy wheel. Pictures help explain what I mean. Can I grind down a little metal from the wheel to let the nut sit in or should I try to turn the nut on the hub so it sits more flush without the angled part sticking out?
Old September 10th, 2016, 12:49 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I replace those drive flange bolts with grade 10.9 cap bolts in this situation. Gives you that little bit of extra room
Old September 10th, 2016, 01:01 PM
Probably not what you want to hear but run wheels that fit without spacers. Your problem is creating more problems.
Old September 10th, 2016, 01:55 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
All of the alloys do it. If you clock the drive flange bolt heads so that the flats align with the outside edge of the drive flange they'll fit. Or replace them with a socket head cap screw.
-Ash
Geared Restoration Co.
352-572-3236
Old September 10th, 2016, 02:42 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Thanks for the input, gents. I'll see what I can do. Cooper Discoverer STT pro in 285/75/16 on deep dish alloys, 30 mm spacers. Tire guy pointed this out and got me all scared. Excited to get some dirt on her.
Old September 10th, 2016, 02:44 PM
Ash's Avatar
Ash
Ash Heller
How are those on the road? I've been eyeing them in the 37" flavor for my 110.
-Ash
352-572-3236
Old September 10th, 2016, 03:25 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
That looks so bitchin'!!!
"Barry is correct!"
Old September 10th, 2016, 03:40 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
-Ash
They are surprisingly very civilized on the road. I came off of Toyo open county. The new tires feel softer as the road feels less harsh to me. The road noise is very quite. Pleasantly surprised. Go for it.
Old September 10th, 2016, 08:02 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I ran spacers with deep dish for 4 years and I didn't have this issue. Different brand of spacers tho.
Old September 10th, 2016, 10:01 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Nice! Socket head caps. Do you know the size? 45 mm? Source?
Found this too: http://www.defender2.net/forum/topic31561-15.html
Old September 10th, 2016, 10:05 PM
Contractor's Avatar
Contractor
Will
1969 IIA
:like:
ac, alloy, wheel, wheels
FS: 16" alloy HD rims with spacers ECR For Sale - Parts 4 January 14th, 2014 10:41 AM
FS: 30mm Alloy Wheel Spacers mgreenspan For Sale - Parts 3 December 23rd, 2013 04:31 PM
For sale: Four freestyle alloy wheels with spacers and nuts Landyman1 For Sale - Parts 4 November 24th, 2013 10:24 PM
WTB Lug Nuts and Spacers for Alloy Boost Wheels on D110 ('93) silverlight Wanted 22 October 18th, 2011 08:58 PM
Freestyle alloy wheels - d-90 wheels d90boy Wanted 7 April 29th, 2010 01:38 PM
