Spacer question - Defender Source
Old June 24th, 2016, 09:14 PM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
Spacer question
Hello,
I am attempting to install freestyle alloys onto my 1985 90. The wheels go on fine without the 30mm spacer but the hub covers poke out of the center cap hole. I also understand that if I do not run spacers my turning radius will be decreased as I am running 285/75/16. The problem I am having is that when the spacer is installed the studs line up with the hub bolts and the alloy wheel will not go on because there is not enough clearance. Enough people run spacers that there must be something stupid I am missing. Any ideas?
Also curious how to use the search function. Is there a way to search for multiple terms at the same time? When I search for multiple words it finds threads that have each individual term. I know about using quotation marks but then the terms have to be in a specific order.
Old June 24th, 2016, 10:34 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
Hmmm. So, you put the holes of the spacer over the studs on the hub. use the provided nuts to bolt the spacer to the hub. Then mount the wheel as you would have -to the spacer.
Old June 24th, 2016, 10:48 PM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
That is how I attempted to mount them but the recessed areas on the back of the alloy only fit on the hub without the spacer. There is more material around the lug holes on the alloy rim and it is hitting the hub with the spacer in place. I will try to get a picture tomorrow.
Old June 24th, 2016, 10:54 PM
defenderholty
Russell
do your spacers have lugs on them as well?
Old June 24th, 2016, 11:07 PM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
Yes. I used the supplied lugs to bolt the spacer to the hub. I have the proper lug nuts to mount the alloy rim to the truck too.
Old June 24th, 2016, 11:24 PM
Your answer can be found within:
http://www.defendersource.com/forum/...new-59298.html
Old June 24th, 2016, 11:34 PM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
So the solution is to grind the inside of the wheel? Not sure I am comfortable with that solution.
Here is a visual.
------ Follow up post added June 24th, 2016 10:37 PM ------
When the spacer is added it rotates the position of where the hub bolts hit the wheel. There are recesses when the spacer is not used that the hub bolts fit into.
Old June 25th, 2016, 12:54 AM
If you are married to the idea of the alloy wheels you can swap out your axles for Disco axles and not need spacers or grind anything.
Old June 25th, 2016, 12:55 AM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
The back went on fine. I had a loose wheel without a heavy tire on it. I was able to look a little closer at how much would need to be ground down. It looks to require very little material to be removed so I will try it in my spare tomorrow. Thanks all.
Old June 25th, 2016, 11:24 AM
swoodard23's Avatar
swoodard23
Scott Woodard
1964 109 Series IIA
I figured it out. It does require minor clearancing. Only took me about 10 min/wheel and only had to be done to the front. I will need to do the spare too.
ac
1989110 ROW spacer question Coloradocarlisle Defender Technical Discussions 4 April 8th, 2016 10:43 AM
DII spring spacer question Tyler Wirken Defender Technical Discussions 1 August 8th, 2013 11:33 PM
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
255/85 wheel spacer experience D90user Defender Technical Discussions 6 July 13th, 2005 11:12 PM
Rovertym 1 inch spacer James For Sale - Parts 0 March 30th, 2005 06:30 PM
