Source of heater core with down pipes? - Defender Source
Old November 16th, 2015, 08:37 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I have a coolant leak, suspected from the heater core. My '85 has the style with 2 pipes that go straight down as they come out of the riveted box. Where can I find a replacement? I looked at Rovers North and Atlantic British- no dice. Any ideas? I'd rather not fork out a million dollars for the Allisport one unless I have to. What else will I need to replace when I'm in there?
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old November 16th, 2015, 08:39 PM
Pull core out and take it to a radiator shop. Boom
Mark Kellgren
KM4BOR
Old November 16th, 2015, 08:49 PM
AAP817
RovahFarm for all your new Land Rover Parts and Accessories
AAP817 | Heater Matrix - with downward facing pipes
HEATER CORE DEF. DOWNWARD FACING, PLN287 - Rovers North - Classic Land Rover Parts
Old November 16th, 2015, 08:53 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys! Anything else that'll likely need to be replaced? I presume there's some kind of foam piece to seal it up?
Old November 16th, 2015, 08:57 PM
Yes. Use albreit to look up part nums
Mark Kellgren
KM4BOR
Old November 16th, 2015, 09:15 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
You guys are the best!
Now to get all the parts here & then installed before we leave for the coast on Sunday...
Old November 16th, 2015, 09:54 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Replace with the straight pipe version - your hoses won't care.
May have both types in stock...
Old November 16th, 2015, 11:15 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Brian:
Ordered from RN. Thanks though. We need to talk about my rebuild at some point!
Cheers,
Paul.
Old November 17th, 2015, 12:31 AM
RBBailey
RBBailey
1965 IIa
I'm going to piggyback on this -- I don't know what type I need. I have an older one with the curved pipes that came out of the box that a previous owner created for the truck.
Am I following you right, Brian, when you say either will work? I am installing a standard type NAS 90 style box.
Project:
1965 IIa SWB
Old November 17th, 2015, 11:40 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Part number STC952 (seal that holds the heater core in place) is back ordered. Anyone have one in stock? Original is shot & Atlantic British doesn't have one.
Old November 17th, 2015, 11:46 AM
I thought the two cores are different dimensions and not interchangeable.
Old November 17th, 2015, 12:29 PM
On the seal stuff, It doesn't look like anything special to me and would be tempted to use a closed cell foam product sized correctly for the job.
Old November 17th, 2015, 12:39 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That's what I thought too - back when I took apart my RHD box to make it LHD I ordered a flat pipe core and it didn't seem that straight forward to get it to work so I exchanged it for the drop pipe version.
Old November 17th, 2015, 12:46 PM
Dimensions: 248 x 178 x 49 mm (5/8" diameter pipes)
Landrover Defender AAP817 Heater Matrix | Landrover Defender Heater Matrix
Dimensions: 280 x 157 x 55 mm (5/8" diameter pipes)
Landrover Defender UTP1725 Heater Matrix | Landrover Defender Heater Matrix
Old November 17th, 2015, 12:50 PM
AAP817
As stated earlier in this thread, the older curved pipes are AAP817.
To be clear:
1. The straight pipe matrices are designed for special straight-pipe heater boxes.
2. The curved pipe matrices are designed for special curved pipe heater boxes.
Yes, the sheet metal on the two different heater boxes do differ.
I have no idea if the straight-pipe core will work in the curved-pipe heater boxes, but I highly doubt curved-pipe cores will work on straight-pipe boxes.
Old November 17th, 2015, 12:52 PM
AAP817
Yes, everyone knows that..... The discussion was because Mybluett suggested you could substitute the newer style for the older. I just wanted it clear so that someone reading this in the future would not try to do it unless it was possible.
Old November 17th, 2015, 01:00 PM
Yeah, I was responding to an earlier post
Old November 17th, 2015, 03:17 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update: Ordered the seal from Rovahfarm. Hope it's in stock!
Old November 17th, 2015, 03:34 PM
For my rebuild, I ordered mine from Craddocks.
Not the cheapest part in the world!
Old November 17th, 2015, 04:12 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
I'm awaiting a downward pipe version from Rovah Farm for an '83 110. To confirm, the straight pipe version does not fit the downward pipe box, too tall by a good bit, I tried after ordering the wrong one.
heater
Heater pipes wanted Mogly406 Wanted 2 March 21st, 2015 12:30 PM
WTB: Heater core matrix with bent pipes Naplm00 Wanted 0 October 8th, 2014 09:22 AM
looking for D-90 V8 Exhaust Down pipes - Non-Cat Ken10017 Wanted 3 January 9th, 2013 03:57 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
Defender LHD E Brake Handles / Wing Heater Pipes SafariHP The Vendors Loft 1 December 15th, 2008 12:04 PM
