Source for Stainless Steel Window Studs and Window Quick Nut Fasteners (D90) - Defender Source
Old August 22nd, 2013, 01:18 PM
Dragon Breath's Avatar
Dragon Breath
Jay
Blank
I'm looking for the stainless steel window studs for my D90 and see that in the past there were some members that were sourcing/selling them.
I'm not sure how much I should expect to pay for them, but did find them at British Atlantic / British Pacific for $108.
http://www.roverparts.com/Parts/9784.cfm
Even if this is a reasonable price I would like to get the corresponding quick nut doortop fastener set but it's currently listed as being out of stock. They're $80 for a set of 4.
http://www.roverparts.com/Parts/9788.cfm
Any guidance on what's a good price and source for either or both of these items woudl be greatly appreciated.
Old August 28th, 2013, 09:34 AM
ssi19's Avatar
ssi19
scott
1995/D90
Did you ever find a reasonably priced set? I need them too.
Old August 28th, 2013, 11:47 AM
Dragon Breath
Jay
Blank
Unfortunately no -- I was a bit surprised not a single person chimed in. If you find a source let me know and I will do the same.
Old August 28th, 2013, 11:51 AM
They have cornered the market. There were a few others making them, but that was years ago.
Old August 28th, 2013, 12:11 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Is gulf coast rovers still around? I thought they were selling them years ago when I hot mine
Jimmy Buffett
Old August 28th, 2013, 02:05 PM
Dragon Breath
Jay
Blank
Thanks -- they appear to be in business still -- here's a link to their soft top window studs. Is it safe to say you're happy with yours?
I really like the idea of having those quick release nuts in my first post -- but haven't seen those anywhere else (and like I said they're out of stock).
http://www.gulfcoastrovers.com/soft-top-window-stud/
Old August 28th, 2013, 02:11 PM
K9Phil
Phil
1994 D-90 #1184
I bought the ss studs from Gulf Coast Rovers and the quicknuts from Rovers North about a year ago. I'm pretty sure I saw the quicknuts advertised by AB recently. Hope that helps.
Old August 28th, 2013, 07:18 PM
ssi19's Avatar
ssi19
scott
1995/D90
These guys have cheap ones. Non galvanized (cadmium plated) steel. http://landroverparts.roversnorth.co...code=VYR500010
Old August 28th, 2013, 07:55 PM
Just get them from Eric at AB and be done with it .
Old August 28th, 2013, 08:37 PM
ssi19's Avatar
ssi19
scott
1995/D90
Yeah prob right. Funny how we all try and be financially responsible and save $30 on accessories after draining $40,000 on a totally impractical twenty year old gas guzzler.
Old August 29th, 2013, 12:19 PM
flippedrover
Tyler
'94 D-90
Don't remember where I got mine from.
Jimmy Buffett
Old August 31st, 2013, 02:00 PM
Dragon Breath
Jay
Blank
Thanks guys.
Phil: Are these the quick nuts you bought?
http://landroverparts.roversnorth.co...ET-OF-4&key=it
If so I assume there were no fit problems going with 2 different aftermarket parts. I haven't found anywhere else that sells the speednuts, so that's my only choice -- $60.
As for the studs, I could buy those cadmium plated ones at Rovers North $56 or .....
The alternative is stainless steel for $90 at Gulf coast or Atlantic British for $108.
Nathan -- I thought about buying it all from AB, but as noted above their speed nuts are out of stock (and my question about when they'll be back in stock hasn't been answered).
Bottom line is I think I'm going to go cadmium and speednuts from Rovers North (and they confirmed what I already believed to be true -- you no longer need the spacer tubes). I think stainless is good, but cadmium should be fine especially where I'm going to be removing the windows seasonally.
Thanks again for all of your input above.
Old August 31st, 2013, 02:08 PM
K9Phil
Phil
1994 D-90 #1184
[QUOTE=Dragon Breath;463637]Thanks guys.
Yes, those are the ones I bought and no fit problems.
Old August 31st, 2013, 07:49 PM
Dragon Breath
Jay
Blank
Thanks -- I just ordered them.
Old September 6th, 2013, 09:19 PM
ssi19's Avatar
ssi19
scott
1995/D90
So ur ordering cadmium studs and quick nuts from RN? Let us know how it all works out when you put them in.
Old September 24th, 2013, 08:17 PM
ssi19's Avatar
ssi19
scott
1995/D90
By the way after some trial and error I found the exact socket that's 1) long enough to grab the stud/nut through the plastic door holes, yet 2) short enough to not be restricted by the bulge near the door handle. I've been getting my window top on and off easily with this. Just keep this socket below and a stubby 1/2 ratchet in the truck. Easy peasy. Can't be much slower than the quick nuts. Certainly cheaper. See below image. Available at Home Depot. Get this exact one. Click image for larger version
Old October 19th, 2013, 12:56 PM
jafir's Avatar
jafir
Jafir Elkurd
Are the studs for older 90s different than the studs for the NAS soft tops? Or more importantly will the newer studs work in my old ex-MOD?
My stud don't have any of the taper that's on the studs I've seen linked on this thread.
Old May 8th, 2017, 10:29 AM
toona's Avatar
toona
Toona
1994 D90
Are these still the best option?
[QUOTE=K9Phil;463639]
Thanks guys.
DOOR TOP SPEEDNUT 10M DEFENDER SET OF 4, KINGFAST2 - Rovers North - Classic Land Rover Parts
Old May 8th, 2017, 10:35 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
When did RN come out with that option? When I purchased ~ 6 years ago, these from AB were the only game in town (or maybe RN was out of stock). The nut is 13mm so the knurled end for the fingers looks to be bigger in dia than the end from RN. Easy to take on and off. As a design change, I'd recommend drilling a weep hole just prior to the threads. Water will find its way under the window top and collect into these nuts.
4 Stainless Steel Quick Nut Doortop Fasteners For Defender - RDF014-598
Old May 8th, 2017, 12:15 PM
toona's Avatar
toona
Toona
1994 D90
I'm not sure but I agree the AB option looks easier. I had those on my old 90 and liked them - just wasnt sure which was better. Has anyone tried both?
90, d90, window
stainless steel studs for st doors mattdh For Sale - Parts 141 December 15th, 2011 09:20 AM
USED defender window studs on ebay eric_besore For Sale - Parts 10 September 3rd, 2005 01:13 AM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Window studs jabber Defender Technical Discussions 1 November 20th, 2004 12:27 AM
SS Window Studs? bugula Defender Technical Discussions 6 May 17th, 2004 04:47 PM
