Source for rear axle - Defender Source
Old September 29th, 2011, 11:35 AM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
The rear axle on my '94 is weeping from the "diff cover" and is having issues with frozen calipers, so I was thinking about just getting a whole new axle. I called Safari Rover, RDS, and RoverGuy. Will has one, but just doing due diligence to see if you guys know of any other sources for a good rear axle.
Pete
Pete
Old September 29th, 2011, 12:10 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I found my axle tube at a local independent mechanic. Any D1 or D90 axle of the era should do. I think the Classics had the same setup as well. You might also try a pick-n-pull junkyard place but you'll probably pay more there.
The new axle, originally... (with carpet porn shot for Barry)
http://www.flickr.com/photos/defende...in/photostream
After media blasting:
Matt from Rock Ware welded some steel straps over the outboard welds. This wasn't necessary but my previous tube failed at the weld (a truly freak occurrence) and it gave me peace of mind:
http://www.flickr.com/photos/defende...n/photostream/
I followed the advice from folks here and prepped it with Eastwood After Blast and then painted it with Eastwood Chassis Black. It has held up beautifully.
Old September 29th, 2011, 12:39 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
A new (used) axle housing isn't going to fix a frozen caliper, and even if you replace the axle housing, you should replace the calipers...they are not that expensive and it's easy job
Where are you "weeping" from? Seeing how the filler plug is the only piece on the diff cover thats removable, I be curious to see a picture...
Old September 29th, 2011, 04:09 PM
peachyracer
Peter Stolz
Thanks, Chris. I was thinking about media blasting it and what to use, so that helps.
Yeah, I figured I'd just get a whole new axle that came with calipers. The steel just got so paper thin in spots on the diff cover over the years in harsh winters that the fluid just weeps out. Unfortunately, I can't get to it right now to get a pic.
Pete
Old September 30th, 2011, 12:42 AM
chris snell
Chris Snell
87 Ex-MOD 110
If I was buying calipers, I would buy new ones, not something that came off an axle from the junkyard. That's just me, though.
Old October 6th, 2011, 11:35 PM
peachyracer
Peter Stolz
So just an update to the "weeping" problem in case this thread comes up in a search, I found diff covers at Atlantic British. I don't have 'em yet, but looks like you cut the old ones off and weld the new ones on. Then, I'll just get new calipers and pads and I'll be walkin' in tall cotton...for a lot less cabbage. Probably take the whole axle off and getting it media blasted it as long as I'm at it.
Old October 7th, 2011, 08:51 AM
I agree on getting one from Keith and make sure the welds are clean else they will leak.
Originally Posted by pendy
I'm here for the D's
axle
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
D90 in Reno, NV with D-90 Source sticker Glenn_Guinto Misc. Chit-Chat 2 September 16th, 2005 09:47 AM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
