Source for hard line (High pressure bypass?) on steering box? - Defender Source
Old October 27th, 2009, 05:13 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Mine fell victim to diesel vibration, contacted an edge, and is leaking bad. I just need the pipe and fittings. I guess I could cut the pipe for the fittings and have one made locally but was wondering if I could source an original or one from a parts truck.
I nicked a photo from RN to clarify,
Old October 27th, 2009, 05:23 PM
61rover's Avatar
61rover
John Crouse
Looks like same basic material as brake line. A good auto parts store will have it.
Old October 27th, 2009, 05:29 PM
It is normal metric thread.
Old October 27th, 2009, 05:39 PM
the flare ends are unique to a PS application. forget about having one made. Best bet is to cut it and rejoin with a compression sleeve.
or get one off a parts truck with a bad box that isn't rusted too bad.
Old October 27th, 2009, 06:51 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Unique in what way Dave? I've got a nice professional flare kit.
Old October 27th, 2009, 08:18 PM
well, I've never had that line out and I don't know what flare kit you have, but the ends of the other two PS lines are not anything then can be done with a typical single/double flaring kit that is typically used for brake and fuel lines. On the other hand a good compression sleeve from your local hydraulic shop will work and probably be under $5. I have one in the high pressure line from the PS pump to the box with no problems.
Old October 27th, 2009, 08:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
What I'll probably do is remove the line with the fittings and go to a local hydraulic shop I know of to see what they can do.
Old October 27th, 2009, 08:42 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Sorry KB....didn't get your call 'till a couple minutes ago when I shut the welder down...finally. The lines I used on your PS originally were factory RRC lines. You can take those to any good hydraulic shop and they can cut the ends off and make you anything you want. You might want to wrap them with some of that spiral wiring loom type stuff like the stock lines are.
I'll give you a shout tommorow about the bulkhead. I'm going home for a nap now.
Matt Browne
Old October 29th, 2009, 04:04 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Flares look pretty ordinary to me Dave. I was able to source a used line from a breaker. I needed to clean it off and use a magnifying glass to actually see the crack which obviously would have gotten worse quickly. Must be a bunch of pressure in that line. I'll solve the clearance issue when I put it all back together and assume I will need to bleed the box.
ID:	22525   Click image for larger version
Old October 29th, 2009, 05:51 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
shoot Kevin... i don't get on here much anymore, but i have a spare one right on the shelf in the garage.
Old October 29th, 2009, 06:08 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I guess I should have asked. It was only $20 shipped so it's not too bad. I would have made my own but the shortest piece of Cunifer line in 5/16" I could find was 6 feet for about $30 and then add shipping.
Old October 29th, 2009, 10:07 PM
hunh.
different flare from the other two lines, they both use an o-ring.
that one does look similar to some of the brake lines I've seen on RR's etc. Couldn't tell you what it actually is though. ISO maybe?
glad you got it sorted out.
Old October 29th, 2009, 10:08 PM
That would be a really thick brake line too.
Old October 29th, 2009, 10:11 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
5/16"
Old October 29th, 2009, 11:06 PM
5/16"
Threads are metric. I had to tap mine out.
Old October 29th, 2009, 11:08 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
FedHill has all the connectors, it's 14mm 1.5 pitch
Old October 29th, 2009, 11:28 PM
I see, but the line itself is not metric then. Got it.
Old October 29th, 2009, 11:33 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It could be 8mm pipe but the difference would only be 3 thousandths of an inch and the flare would come out identical.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
1984 Defender 110 power steering line washer/seal (low pressure side) cgalpin Defender Technical Discussions 3 February 23rd, 2009 12:52 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
» Defender Registry
Stu II
Greenbull
Hank
D110
Add your Defender
