Source for fuel filler hose - Defender Source
Old September 29th, 2007, 01:04 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Anyone know of a good source for filler hose at a reasonable cost? I only need about 6" of 3" O.D hose but I want it to be multi fuel resistant. I have an excel tank in the rear wing of the 110 and the line that goes between the that and the main tank is getting soft and seeping from biodiesel.
Cheers
Old September 29th, 2007, 01:36 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Check with West Marine or Boat US, whatever you have close by. They should have sections of hose on the shelf. Not the cheapest but you can walk in and walk out with it. I am not sure what it will be rated for, but you can check that out when you get there.
Old September 29th, 2007, 01:47 PM
D90user's Avatar
D90user
steve
good idea Andrew...why didn't I think of that, I was just at west marine.
cheers
Old September 29th, 2007, 08:28 PM
I got mine from RDS
Old September 29th, 2007, 11:32 PM
D90user's Avatar
D90user
steve
I was thinking about calling George, but I think the OE one is not biodiesel resistant.
Old September 30th, 2007, 07:48 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
What hoses in a diesel need to be changed for biodiesel use? I assumed the problem was mainly the small ones at the engine.
Old September 30th, 2007, 11:57 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Napa has it too...
Old October 2nd, 2007, 07:13 PM
D90user's Avatar
D90user
steve
There are some small sections of hose that are easily switched with "SAE 30 R9" hose from kragen...mostly under the hoos but there area a couple of connectors around the tank depending on your setup.
Napa does not carry 3" O.D. filler hose...
For the record:
http://www.hosexpress.com/hose/marine/SW-469.htm
http://www.ushosecorp.com/index.cfm/...uctID/1686.htm
Old October 2nd, 2007, 09:07 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Thanks Steve for the information.
Old October 3rd, 2007, 01:30 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I would definitely recommend using SAE J30R9 hose whether running biodiesel or just plain diesel. I've had problems with J30R7 hose cracking with just diesel fuel. I'm switching over to all J30R9 hose as I'll be running both bio and diesel. J30R9 hose is suppose to have a fluoroelastomer liner that minimizes permeation into the rubber. It's also way more expensive than J30R7, but you don't really need too much.
Steve - Thanks for the source for the fuel filler hose.
Old October 3rd, 2007, 02:25 AM
D90user's Avatar
D90user
steve
Originally Posted by D90user
Whoops... make sure you order from this link...the other was a nitrile hose which is a no no.
no problemo gentlemen
Old October 20th, 2009, 09:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Fuel Filler hose is getting soft
My fuel filler hose is getting soft and just started leaking. I run Biodiesel all year round. Since the fuel system assembly was installed new just 5 years ago I assumed they used synthetic hoses only. This appears not to be the case as you can see in the picture. Do I need to drop the tank to be able to replace this hose?
What type of hose should I replace it with (Willcox Hose?) and where do I get it?
Thanks!
Name:	Fuel Filler Hose.JPG
Old October 20th, 2009, 09:45 PM
I don't know what you want to replace it with. I ran bio for a long time and never had a problem. Anyway, you don't need to drop the tank, just put slices in the hose after you remove the hose clamps and pry it off. The new one will go on nice and easy with some lube.
Old October 20th, 2009, 10:48 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Jim,
What blend do you run? I'm running B99. That high of a blend can damage the hoses. Rovers North did my 300tdi install and I have put in a request to find out what type of hoses they used for the fuel system. I just want to make sure it is not degrading and leaving residue that ends up damaging my engine. The filler hose feels really soft. Is it supposed to be soft?
Old October 21st, 2009, 06:59 AM
It was b100 and b99 after they came out with the blend rule. It very well could be a natural rubber fill hose, but all I was saying was that I don't know the composition of new hoses, so I don't know really what to recommend. I did install a new hose when I did mine and didn't have a problem, so perhaps the composition changed. I ran bio long enough to ruin the little return hoses on top of the engine, so I suspect my fill hose would have been compromised also.
If your truck was NAS converted to tdi, I bet they just left the original fuel lines in it, why don't you inspect them where they enter the lift pump? I'm sure you'll notice if they are looking bad.
Old October 21st, 2009, 11:00 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I have a brand new 110 filler hose (http://www.lrseries.com/shop/product...LLER-HOSE.html) that I bought from LR Series a while back. Couldn't use it as I didn't realize the HCPU hose is a bit longer. Doh! Wasn't worth returning. $30 shipped.
While we're on the subject: I've noticed that the gasket on my diesel cap has gone soft. Needless to say, hard left turns with a full tank and I lose diesel. Dunno if it's from running biodiesel or not.
Chance
Old October 21st, 2009, 11:52 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I heard back from RN this morning. It is indeed a natural rubber hose. All OEM filler hoses were (are?) natural rubber. They left the old fuel system in place. A viton hose would be ideal but they don't make them that size. Still a synthetic hose would be a major improvement over the rubber one.
Chance, thanks for the offer. Is this a synthetic hose? It doesn't appear to be long enough to fit my 90. My filler cap started leaking a bit too. I'm suspecting the gasket is natural rubber?
Here's some good info I got from the guys at Greaseworks here in OR regarding Biodiesel and hose compatibility:
"Biodiesel permeation of fuel lines is the first sign of fuel hose degradation, and does not appear to affect performance. However, if "sweaty" hoses are left on the vehicle, the next phase of degradation--loss of elasticity--can hinder performance. When a fuel hose loses its elasticity it becomes mushy, and does not exhibit rebound when exposed to the Squeeze Test: Squeeze the suspect hose between two fingers and note its elasticity or rebound. If it does not spring back to round, it has failed this test and should be replaced. Hoses that cannot hold their round shape are prone to collapsing under the relatively low-'pressure' vacuum (3-8 in/Hg on pre-92 VW diesels) of the fuel injection pump, thus restricting fuel-flow and potentially leading to a fuel-starved engine.
The next phase of fuel hose degradation is hose swelling and splitting. This is generally a long-term phenomena (>6 months B100 use) and will eventually lead to a complete failure of the affected hose, either by a breach in the hose wall, or by literally melting an end off, usually at a hose clamp. While many hoses seem to initially handle B100 quite nicely, very few can handle continued B100 use over the long-term. Viton® fluoroelastomer hose is one group of hoses that is B100 resistant over the long-term, (rated at 400* F continuous use), and is far and away the best option at present for long-term B100 use."
Old October 21st, 2009, 12:54 PM
Chance, I'll take your hose.
Old October 21st, 2009, 02:50 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Nah, I'm sure the replacement part is natural rubber. The gasket appears to be the same. Might as well cut a new one out of an inner tube. I wonder if NAPA sells rubber gasket material.
For better or for worse, all I can get around here is B5. If I drive to Denver, I can get B20 (which is all I probably want to run here in the winter anyway).
Ooooh, that don't sound right.
You got it. Paypal to geurin at gmail is OK. Make sure your VIN is in the right range:
Part number: NTC2337
Applicable Models:
Defender 110 to vin WA159809
Product Description:
Fuel filler hose, main for under rear body fuel tank 110" models.
Chance
Old October 21st, 2009, 03:45 PM
Damn you!
Can I have the used one then? Please don't cut it or at least give me the one I sent with you on the tank I gave to you. I need something.
fuel
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
