Source for chassis (tail) harness - Page 2 - Defender Source
Old September 23rd, 2012, 11:23 AM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
Originally Posted by rovertek View Post
I agree with using factory conectors but i eliminate the bullet connectors there just plain shit and exspose the wire to corrosion.....most of my customers requested no connectors at all .....
Looking at RAVE for the NAS Defender, the majority of the connectors are AMP/Tyco 070 series Econoseal III, with some Sumitomo sealed HW and HM series and, what looks like, AMP/Tyco 250 series Econoseal III.
I may be able to supply some of these, or point you towards a supplier.
Paul.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old September 23rd, 2012, 11:39 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Picked up some supplies last night.....as for the connectors going to look at all option possibly found a US supplier ....
No Mall crawler here
Old October 11th, 2012, 05:19 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
GOOD NEWS!! located and ordered the proper connectors at the bulkhead ....
so the harness will have all new pins and wire from the bulk head to the taillights
now just have to source the correct wire colors ........
Old October 14th, 2012, 09:47 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
http://www.flickr.com/photos/defende...ream/lightbox/
Old October 14th, 2012, 10:23 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
i'm in the middle of completing one right now i actually split up the harness into 3 individual units ....fuel pump harness , rear taillight harness and interior /aux harness much easier to locate a problem and if you lose a ground or short the taillight harness the fuel pump harness is totally separated not sharing the same ground or in the same loom just my .02 i would dump those brit connectors in the rear too susceptible to water intrution
Old October 14th, 2012, 10:48 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
OK so this is what i started with and here's a pic of the left side taillight ,just have to re secure the new harness .. all connections are soldered and industrial heat shrinked.."no connectors" customers request and i also put the anti chaff harness loom on after the pic ill try to get some more updates soon ...
and if your wondering blk/white=marker light...red/white = brake ...brown.=.reverse...blue/white = lt blinker black = ground ..until i source the correct wire colors
ID:	59056   Click image for larger version
Old October 14th, 2012, 11:19 PM
chris snell
Chris Snell
87 Ex-MOD 110
In the first pic, it looks like you used the factory harness and just spliced in the sub-harnesses.
I'm going to take a stab at building a fresh harness entirely. If that becomes too much of a nightmare, plan B is to try to find a late 94 harness and modify it to work.
Does anyone here know the differences between the early 94 and late 94 chassis harnesses?
Old October 14th, 2012, 11:37 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
actually i just cut it in the middle to remove it easier with the rats nest in the back ,i built the harness totally from the bulkhead connectors back . once you cut it apart you'll find some weird things when they built it .. the harness that i'm building now is for a 97 auto wagon so there's a rear wiper / defrost rear light ect , customer requested to remove the speaker wires ..
as for the stupid connectors in the rear you can simplify with weather packs or something similar much easier with all new wire too
Old February 5th, 2013, 02:40 PM
chris snell
Chris Snell
87 Ex-MOD 110
As a follow-up for anyone finding this thread, details for acquiring and installing a new harness can be found here:
http://www.defendersource.com/forum/...ad.php?t=42986
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
TAIL LAMP PROBLEMS...where can I source PARTS tebby Defender Technical Discussions 19 November 2nd, 2010 12:40 PM
NAS Rear Tail Gate Stewperformer Wanted 9 March 23rd, 2006 08:35 PM
D90 in Reno, NV with D-90 Source sticker Glenn_Guinto Misc. Chit-Chat 2 September 16th, 2005 09:47 AM
94 Square Tail lights switch to 95/97 ?? mfreeman17 Defender Technical Discussions 12 May 17th, 2004 04:58 PM
