Sound of marbles under acceleration? - Defender Source
Old January 12th, 2018, 07:00 PM
El Matador
Jesus
'91 110 Ex-Mod
Hey y’all,
Just curious is this is a normal sound or not on my 2.5 na. Whenever I step on the gas pedal with any force it sounds like Marbles rolling. It’s the weirdest thing. It doesn’t happen under light acceleration.
Any ideas what it might be?
Cheers,
J
Old January 12th, 2018, 07:08 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Not familiar with that sound. If new to you, have you replaced all fluids, timed the IP, and adjusted tappets?
If only under load sounds like a fueling issue. Red90 will know, most likely.
KGH - “Stinky LR diesel” Defender Snob
Old January 12th, 2018, 07:33 PM
No idea. Maybe try and make a video. Maybe a u-joint if it changes with throttle load?
There is a light and hard acceleration with a 2.5?
Old January 12th, 2018, 07:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I had to look up a video to hear what "rolling marbles" sound like. I still can't tell.. maybe top end noise, exhaust leak?
Old January 12th, 2018, 07:51 PM
El Matador
Jesus
'91 110 Ex-Mod
I’ll take a vid as soon as I can. Thanks y’all. All Fluids have been replaced recently, though noise persisted afterwards.
------ Follow up post added January 12th, 2018 06:52 PM ------
@red90 there’s: “pushed by a light breeze” and then there’s: “pushed by an asthmatic mouse”. The difference is marked
Old January 12th, 2018, 11:22 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I'm gonna go ahead and say it, that's the sound of a 2.5 n/a crying to be put out of its misery. Just do it, it needs to be done.
Old January 12th, 2018, 11:34 PM
El Matador
Jesus
'91 110 Ex-Mod
Lol! Saving up for that 2.8 repower
Old January 12th, 2018, 11:56 PM
and the band played on....
Old January 13th, 2018, 05:46 AM
phoenix37's Avatar
phoenix37
john
leftover acorn shells from the squirrels that power that thing...
Old January 13th, 2018, 10:30 AM
s3landy
Mike Wallace
Had a weird issue with my 200tdi years ago. Sounded like someone throwing a handful of gravel or marbles under the truck against something metal. Mine only seemed to happen when I would stop more abruptly than normal. Turned out during past clutch work, the previous owner left pieces of broken brass throw-out fork pieces(if you know what I mean) in the bell housing.
Old January 13th, 2018, 10:34 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Have you had this Landy long?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 13th, 2018, 11:32 AM
first move would be to narrow down where its coming from.
1.does this happen only while moving?
2.in all gears?
3.in neutral?
4.if clutch pedal is up?
5.if clutch pedal is down?
6.in diff lock?
if it happens while stationary as well, put the transfer box in neutral and repeat 2 through 5
If it is internal to the engine, it may not occur while stationary since the engine isn't working as hard.
if it's isolated to one gear then its probably the gearbox
is the exhaust system properly secured to the vehicle?
all lugnuts tight?
handbrake drum tight?
if it goes away with the clutch pedal down, it might be the throwout bearing.
if it goes away in diff lock it could be a driveshaft thing although I find I usually hear those at low speeds first and not on the highway.
to check driveshaft u-joints, chock the wheels and put the car in neutral with the handbrake off.
grab each driveshaft on either side of each u joint and see there's any rotational movement between the two bits. do the same for the splined joint in the middle of the shaft. any perceptible movement indicates a joint needing replaced. you can get away with some slop in the sliding spline but not much.
if its only while moving, try flooring it (just long enough to hear it, don't blow up your engine haha) going up a steep hill, that should increase the loading and exacerbate the issue if its internal to the engine.
anyway...good luck with it. let us know.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 13th, 2018, 11:48 AM
NADA
When u r in the wrong gear...ie 5th and stomp a laboring or underpowered engine it can make a noise like that
Old January 13th, 2018, 04:52 PM
El Matador
Jesus
'91 110 Ex-Mod
Woah thanks guys! I’ll get on the list that @ren Ching suggested and come back with answers.
Old January 13th, 2018, 07:07 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Dave, I'll go ahead and answer for Jesus.
1. Yes, it's a 2.5 n/a it makes hideous rattling noises when it's moving.
2. Yes, the more gears you use the more death rattles it makes.
3. Of course it moans, groans and rattles - it's internal parts are moving therefore it makes death noises.
4. You betcha.
5. Hell yea.
6. Why wouldn't it? It's a 2.5 n/a.
Having to repeat steps 2-6 is too painful.
I can't tell if it's internal to the engine because ABSOLUTELY EVERYTHING IS RATTLING- EVERYTHING!!!
Every gear, no gears, all gears, some gears, random gears whatever.
Of course the exhaust system is not properly secured it rattled lose shortly after it left the factory because its attached to a 2.5 n/a.
The 2.5 n/a constantly rattles the lug nuts lose along with my fillings and bowels.
See answer above.
Because I have ADD/dyslexicia I'll just put the rest of your queries in the "if a tree falls in the woods does it make a sound?" category. No because some ding-a-ling with a Defender with a 2.5 n/a was rattling, belching smoking and making so much damn noise while it's running in the woods even the bear couldn't concentrate and had to go find somewhere else to take a shit much less hearing a damn tree fall somewhere.
Any other 2.5 n/a rattling questions I can help you with?
Old January 13th, 2018, 07:29 PM
El Matador
Jesus
'91 110 Ex-Mod
4. You betcha.
5. Hell yea.
See answer above.
I tried to read this, but couldn’t concentrate over the Rattling of the 2.5na. I assume it holds the answer to my problem as well as the answer to life, the universe, and everything.
Old January 14th, 2018, 09:29 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Haha! If you have any other questions about the venerable 2.5 n/a just let me know.
Old January 14th, 2018, 09:39 AM
Chris B
72 + D1 drivetrain =?
To my ears the 200tdi and earlier engines sound like a box of lug nuts being shaken in a tin can..
Old January 14th, 2018, 09:45 AM
Only if you have something wrong.
Old January 14th, 2018, 10:30 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Jesus, have you owned a diesel before? There’s a reason it’s called dieseling when you turn a gas engine off and it continues to run bucking, knocking, and wheezing. They are noisy. When you accelerate, it sounds like a baritone opera singer going arg, arg, arg, Arg, ARg, ARG!
Sometimes the vibration causes a loose heat shield to vibrate sounding like rocks in a can, sometimes a loose or broken motor mount causes the exhaust to bang against the frame, sometimes every noise in a newly purchased LR causes a freak out moment.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
ac
"backfire" sound under acceleration + engine dies ymc226 Defender Technical Discussions 23 April 23rd, 2017 01:23 PM
Metallic / chugging sound under load TELOS Defender Technical Discussions 1 March 1st, 2017 04:07 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
