Sound from under truck - Defender Source
Old April 23rd, 2010, 02:43 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I'm getting an intermittent noise coming from the back of my truck. Kind of sounds like a thin rod of metal is bouncing off something spinning. Not very loud and comes and go. I have checked all over the thing for something loose bit found nothing.
Only occurs when moving and seems to speed up with that.
Any ideas!?
Old April 23rd, 2010, 03:48 PM
Is everything full of oil that should be?
Ron
Old April 23rd, 2010, 03:53 PM
Campbell's Avatar
Campbell
Rich Campbell
Yes all oil is full. Seems to come and go and is coming from the back of the truck.
Old April 23rd, 2010, 03:55 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
where the sections of exhaust pipe come together may have loosen up
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
Loose torque converter?
Navy. It's not just a job, it's a job on a ship.
Old April 23rd, 2010, 05:11 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Stone trapped between a rotor and a backing plate?
Old April 23rd, 2010, 07:32 PM
Campbell's Avatar
Campbell
Rich Campbell
Stone??
I will check that out. It does seem to be coming from drivers rear wheel.
Do I need to pull the wheel or can you remove the back plate from the back with the wheel on.
Old April 24th, 2010, 08:20 AM
Campbell's Avatar
Campbell
Rich Campbell
Not a stone. Good idea though. Much worse this morning. Sounds like a bad rattle. Coming from what appears to be the rear wheel. Has the sound of something bouncing around metal. I just had it inspected so maybe something in the brakes came loose? I search and found most tcase/diff problems cause a different noise. Maybe its a bearing? U joint?
Old April 24th, 2010, 09:08 AM
Richard, diagnosing the u-joints should be easy. Chock one side the the axle, jack up the other side, and put the transmission and/or transfer case in neutral. You should be able to spin the lifted wheel and driveshaft freely and there should be no pressure on the joints. You should be able to push/pull on them and not feel any play, event using a small pry bar inbetween the joints to check them.
Likewise if you think it's around the wheel, spin it and see if you hear the noise. Check the bearings by grabbing at 12 and 6 o-clock and push/pull in opposite directions.
hth,
charles
Old April 24th, 2010, 09:45 AM
Campbell's Avatar
Campbell
Rich Campbell
will do....thanks
Old April 24th, 2010, 10:28 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Check for a loose shock.
Old April 26th, 2010, 08:57 AM
Campbell's Avatar
Campbell
Rich Campbell
Pulled the wheel and check it for any wobble and there wasn't any. So I guess the bearing is ok. I jacked it up and it had some play turning the wheel since the other wheel was still on the ground. Maybe 2" play both ways....not sure if that is normal. The shock and spring seemed tight.
Noise comes and go's. Everything seems tight.
Old April 26th, 2010, 09:28 AM
What about the u-joints? did you check them when you had a wheel up? Some play is normal because it's spread out over a bunch of things that add up. 2" doesn't sound ideal, but not terrible.
Old April 26th, 2010, 09:38 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Did you wiggle the exhaust pipe and even the plastic wheel arch? You never know... Brake backing plate loose? Did you take the tire off and inspect the area?
Does your truck have a rear locker in it?
Legend in My Own Mind.
Old April 26th, 2010, 09:40 AM
Campbell's Avatar
Campbell
Rich Campbell
I didn't check the u-joints. That will be tonight, I just forgot about that since I was sure it was the bearing.
So I should jack one side up, put the tcase in neutral and spin the wheel? Am I only looking to replicate the noise of something else.....probably a dumb question.
Rich
Old April 26th, 2010, 09:46 AM
Jack up one side and put the tcase in neutral, take off hand brake. Spinning the wheel just verifies you have no pressure ont he joints. Then get under there and tug at the driveshaft, try twisting it etc. If the u-joints are bad it should be pretty obvious when there is no pressure on them. But if necessary use a small pry bar to put pressure on the joint and look for any movement. But usually once the pressure is off you can tell right away they are bad.
Old April 26th, 2010, 10:50 AM
Campbell's Avatar
Campbell
Rich Campbell
Cool....thanks.
Rich
SEMA truck roverboy Misc. Chit-Chat 15 November 18th, 2006 09:09 PM
Yet another Truck Wont start... arbik Defender Technical Discussions 12 September 21st, 2006 03:51 AM
Want a Project Truck Brent Nevin Wanted 8 June 29th, 2005 02:28 PM
Cool Truck TDI Guy Misc. Chit-Chat 13 May 27th, 2005 06:40 AM
And I thought the D-90 looked like a dump truck! OCD90 Misc. Chit-Chat 0 September 16th, 2004 07:40 PM
