Sound from Fan - Defender Source
Old February 20th, 2013, 07:28 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Sound from Fan
So when i got home from ROMPi noticed the engine had a bit of a louder sound than i was used to, it didn't really change with revs, but also once i revved it it go drowned out.
Popped the hood at idle and i noticed it seemed to be coming from the front of the engine by the fan, inside the truck it sounds like a bit of a rumble, but with the hood open it sounds like the fan is really loud.
Put my ear in front of the radiatior, and it sounds like its sucking in alot of air, which may or may not be the way its always sounded, i never really stuck my ear next to the radiator before.
I read a bunch of post about how to check if the fan clutch is shot, but still am not sure if mine is. No i didn't try and stop it with a newspaper... i dont want to risk breaking a plastic blade thats probably brittle in this cold weather
w/ a cold engine off, if i try to spin the blades wheel of fortune style they spin maybe 1/4 turn or less and stop. its not siezed up, and has some resistance. Does this sound like its working properly?
I guess the next thing to do would be remove the belt, and see if the sound goes away. If so I know its either the fan or maybe the water pump (but the fact it sounds like the fan is loud tells me its not the water pump) It certainly is NOT a high pitch sound or any sort of squealing or squeeking.
I'm thinking about selling the truck (although it didn't sell on ebay), and would like to sort this out before passing it on to the next person.
Old February 21st, 2013, 05:32 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Here's a video of me trying to spin the fan when the engine is cold. I'm giving it my best wheel of fortune spin. http://youtu.be/qsR5KjGErss
Old February 21st, 2013, 05:58 PM
It is broken. It has siezed locked on. It should spin free when cold.
Old February 21st, 2013, 06:14 PM
bossman429's Avatar
bossman429
Adrian
1988 90
When you say freely do you mean full rotation? Multiple rotations? Etc
Old February 21st, 2013, 07:22 PM
Yes. It should have minimal resistance cold.
Old February 21st, 2013, 09:19 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It will not spin freely like a bicycle wheel but will rotate with a little pressure applied.
Land Rover 110
Old February 21st, 2013, 09:29 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Well mine does this....
Old March 10th, 2013, 06:33 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So I took off the fan and clutch, and the sound was still there, albeit much more subdued. I swapped the fan onto a brand new Oem viscous clutch and put it back on, fired it up and the sound was there and back to the original sound level. Here's a vid I took. It's hard to hear but you hear a kind of rumble sound, on and off a little. I'm thinking maybe a bad water pump? It's almost grinding like. You can't hear it as well when the engine is revved, but you do notice it on idle.
http://youtu.be/gXu9lUB1YUY
Old March 10th, 2013, 06:48 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Get yourself a Mechanic's Stethoscope and see if you can pinpoint the source. Tough to tell from the video where the sound is coming from.
Old March 10th, 2013, 06:52 PM
bossman429's Avatar
bossman429
Adrian
1988 90
You get what sound I'm talking about though right?
Not sure if its audible to others in the video. I hear it but it may be because I know what I'm listening for
Old March 11th, 2013, 12:51 PM
USLandy's Avatar
USLandy
Andrew
defender 90
could be the tensioner bearings going...
Old March 11th, 2013, 03:06 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Checked the water pump pulley. It has play in it. Gonna assume that's it
New one on order for 85 bones
There is no tensioner on these belts
Old March 11th, 2013, 04:24 PM
When my water pump was going, it gave off few noises until the end. What I got was screeching an general unhappiness from under the hood. When it sieze nothing would work.
Old March 13th, 2013, 12:59 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So i took the water pump out (new one should be here Friday), and this is the sound it was making, sounds very much like the sound i was hearing, and the pulley and fan only amplified it more. very confident this will fix it.
http://www.youtube.com/embed/DFXlyr1...xOOlM3dufklQFA"
Next question - do you guys use the paper gasket that comes with the WP or do you prefer silicone? I've had great success with silicone for applications like this (T-Stat, drive flanges etc), and only seen paper gaskets leak. The WP had some silicone on it and no gasket. It did not leak a drop.
Old March 13th, 2013, 01:31 PM
I used silicone gasket maker smeared on the paper gasket - no leaks.
Old March 13th, 2013, 01:35 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Same here...
Old March 14th, 2013, 08:39 PM
bossman429's Avatar
bossman429
Adrian
1988 90
New water pump in. All better.
Here a bench comparison
http://youtu.be/8Sh4_uY-FRo
I just used silicone gasket maker and not the paper gasket. I figure id stick with what has worked for me in the past.
I did have one bolt strip out though. Was able to drill and re tap it with a m10. I don't know why they aren't all studs instead of bolts.
fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Dead Heater Fan chris snell Defender Technical Discussions 4 January 25th, 2006 11:07 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
