Someone who knows a Warn Really well.. - Defender Source
Old April 2nd, 2008, 09:45 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I'm sure this is a stupid idea but it's all I got. Here is my issue. I have 3 winches. One on my truck (8k), one on a multi mont (9k) and a 15K off my old rangie. The motor blew out on the 15k and warn replaced it under warranty. I disassembled it sent it to them and they sent it back but i'm not sure I put together correctly. Since then I have lost the control box but I want to test it. What I was thinking I would do is hook up the 9K to the back of the defender, hook the 15K to a battery and then run a jumper cable from the 9k to the 15 so I could piggy back off it's control box. I can't seem to get the warn site to give me a wiring diagram. Does anyone know which of the three wires coming off the winch goes to what? F1, F2, F3 I believe they are called? Will this work if hooked up correctly? (I'm really bad with electrical stuff) THanks.
Old April 2nd, 2008, 09:53 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Hmm, that seems complicated..
Test procedure for most warns though;
1. Put the winch in free spool
2. Disconnect the positive lead from the battery (Leave the ground lead attached)
3. Label and disconnect the three cables that run from the control pack to the three posts on the motor (You can skip this since you don't have a control pack)
4. Stamped next to the three posts on the motor will be an 'A', 'F1', and 'F2'. Run a small jumper wire (5"-6" dead lead, 8ga. will work just fine) from 'A' to 'F1' and put power from the battery (jumper cables work well) to F2. The winch motor should run in one direction at this time.
5. Next, place the jumper wire from 'A' to 'F2' and put power from the battery to 'F1'. The winch motor should run in the opposite direction this time.
If these steps are followed correctly and the motor runs in both directions, then the motor is good.
Make sure you have ground going to the winch motor as well.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old April 2nd, 2008, 09:59 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
so F2 and F3 on the 15 would be positive and negative on the battery?
Old April 2nd, 2008, 10:05 AM
rmuller
Ryan
No... well, not as far as I know... With my Winch which is a Warn XD9000, and other winches i've seen, there are three posts on the top of the motor, A, F1, F2 ... then there is a ground bolt on the bottom of the motor.. I hooked my ground to a good ground on the chassis, then plug the A, F1, F2 from the solenoid box, then there is a power cable that gets run directly to the battery on the solenoid box, and a smaller ground wire.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old April 2nd, 2008, 10:27 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
A, F1 and F2 are all live
3rd low and BOOT IT
Old April 2nd, 2008, 03:27 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
http://www.ramseypdfs.com/owners_sea...499-0905-H.pdf
See page 11 diagrams. Same test procedure for your motor.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 2nd, 2008, 03:37 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I will try to follow the diagram, thanks!
Old April 2nd, 2008, 04:05 PM
outfield
Steve
1995 D-90 SW #351
PM sent
Power Tanks and warn winch TDI Guy Misc. Chit-Chat 10 April 29th, 2005 12:57 AM
Husky 10 with Warn Remote?? priest944 Defender Technical Discussions 7 March 31st, 2005 07:56 PM
Sitting Level - OME & ARB Bull Bar w/ Warn Winch TurkD90 Defender Technical Discussions 23 January 5th, 2005 10:44 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
Warn XD9000i in ARB brush bar... Trigger Defender Technical Discussions 2 June 15th, 2004 12:26 AM
