Some weird noise - Defender Source
Old February 28th, 2005, 11:50 AM
spencer08291985
Tim/Spencer
Exclamation Some weird noise
What about a clunking noise, from the engine compartment on a 97' D-90. Sounds like something slapping the side of the oil pan,(when i think of what it sounds like i think of an oil stirrir on a briggs and straton motor if anyone knows what i mean) has been doing it for a while but seems to be getting worse, doesn't do it at high rpm's. runs great, only 49,000 on whole vehicle and less than 12,000 on new motor that was installed about 3 years ago, I am the second owner, my dad being the first and i am not sure if the last motor did this? any suggestions are these noises common? If anyone has any ideas i would appreciate it, you can email me at spencer08291985@yahoo.com. Thanks
P.S. I am not very fimiliar with this site,If someone post a reply on the website to my question how will i know?
Old February 28th, 2005, 12:49 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Spencer.
Anything from the oil pan makes me concerned. Even if it's nothing major in the engine, it may have an effect on your oil supply. I'd take the oil pan off and check the condition of the oil pickup tube, look for anything loose flopping around, and also check the connecting rods.
Also. New posts get automatically moved to the top. Once that have been replied to since you last checked will have the little envelope turn a different color.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 28th, 2005, 03:58 PM
If it's coming from the pan drop the pan and check it out, just like Hans said.
If you look at the top of this thread there is a drop down called thread tools, click it then click subscribe to thread and you will get an e-mail notifying you that someone has replied to the thread. It will send the e-mail to the address in you profile.
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
