some random questions - Defender Source
Old June 19th, 2012, 11:43 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
As my D90 is new to me I have some random questions. If anyone has any answers I am greatful for the feedback.
1- My personal feeling is my breaks are week. I have the stock setup and my truck sat for 3 years unused before I came upon it. I figured 4 pistons up front and drums in the rear would have more stopping power.
2- As the tech does not indicate redline what is the redline RPM on the 3.9 V8?
3- I can't seem to find a jack or a location to store the jack. Where would this be?
4- How do I know what transmition and transfer case I have (other them crawling underneath and reading some # off the case)?
5- Is there a trick/fix I can do to get the slide windows to stop clanking?
6- My heater fan only runs on high, I assume its a relay or fuse but I can't find either. Any hints?
7- Is there a why to adjust the camber on the D90?
8- I read soemwhere that an NAS D90 only says Defender on the rear plate. Mine says Defender 90. I guess that was bad info?
9- any one know what this is (see picture)?
I think that is most of it. Thanks for your help in advance!
Old June 19th, 2012, 11:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
See below:
You have discs at all four corners. Being the truck sat I would check all the pads and rotors and fluid. A good flush isn't a bad idea.
2- As the tech does not indicate redline what is the redline RPM on the 3.9 V8? Why? Planning a drag race?
3- I can't seem to find a jack or a location to store the jack. Where would this be? Under passenger seat.
4- How do I know what transmition and transfer case I have (other them crawling underneath and reading some # off the case)? R380 transmission and LT230 transfer box
5- Is there a trick/fix I can do to get the slide windows to stop clanking? Search window replacement felt.
6- My heater fan only runs on high, I assume its a relay or fuse but I can't find either. Any hints? Could be the switch. I had the contacts go on it.
7- Is there a why to adjust the camber on the D90? Not that I know of. Why?
8- I read soemwhere that an NAS D90 only says Defender on the rear plate. Mine says Defender 90. I guess that was bad info? Yup
9- any one know what this is (see picture)? Wheel chock when jacking up the truck.
Attachment 53226[/QUOTE]
Enjoy the truck
Old June 20th, 2012, 12:02 AM
Nice work Barry.
For the heater fan, very stupid question. Is this controlled soley by the lever-type switch on the dash binnacle? Mine doesn't seem to work at all. What did you do to fix the contacts?
Old June 20th, 2012, 12:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
Nice work Barry.
When I got my truck the switch only went half way up before it would get stuck. In this position it was fully off. If I slid it down to the first click that was low, next click was high. I was convinced it didn't work correctly so I replaced the switch. The new switch goes to the top but as far as I can tell there is no reason to. Once it shuts off half way up there is no reason to slide it to the top. I always thought there were even lower settings but I have never been in a truck where there were.
Old June 20th, 2012, 12:38 AM
Where'd you source the new switch?
Old June 20th, 2012, 01:02 AM
bjf's Avatar
bjf
barry f
94 ST #395
Rovers north
Old June 20th, 2012, 01:50 AM
michael67's Avatar
michael67
Michael White
110 Tdi
The low setting on mine is so bad I can only hear it if the engine is off, and can only tell a difference if the truck is not moving. And this is with a new switch and a new fan. Try turning it on low with the engine off and the key in the "on" position and see if you can hear it moving.
Old June 20th, 2012, 08:45 AM
Jack goes under driver seat
Old June 20th, 2012, 08:53 AM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
All the way up closes outside air from coming into the cabin. Half way position then outside air comes inside but no fan (when cruising for example) and then you have 1st and 2nd speed.
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old June 20th, 2012, 08:58 AM
They are all shit ... Lowest speed is like an asthmatic kitten blowing out birthday candles, if it even moves at all ... Nothing to do with the switch ... Everything to do with poor design. I'm surprised no-one makes an upgrade
Old June 20th, 2012, 09:15 AM
There was. Guy on here selling really nice kits the replced the felt in the sw/st window frames. I can't remember the name of the company.
------ Follow up post added June 20th, 2012 09:19 AM ------
http://www.garrisonoutfitters.com/
Old June 20th, 2012, 11:39 AM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
. . . Lowest speed is like an asthmatic kitten blowing out birthday candles, if it even moves at all . . .
Pure poetry. Love it.
Old June 20th, 2012, 10:51 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Question #2. I've always been curious about that too.
Old June 21st, 2012, 07:23 PM
petminded's Avatar
petminded
David
Thanks all!
Here are some of the answers to your questions to me:
I guess I don't have a jack. I've looked under both the drivers and passangers seats.
Drag racing is fine by me but I really just want to know so I don't blow the engine when merging onto the highway.
I guess is should be happy that my fan blows anything - dust included- since it sat so long. The lever goes past 3 clicks and the last is the high speed. Now I know I have an asamatic kitten trapped in my dash. But does anyone know where I deposit the food for the poor thing?
Being stock I was hoping the next set of tires would not wear so poorly. But now you have saved me the cost of an alinement.
Sorry if I missed any questions. Thanks for all your help.
Old June 21st, 2012, 07:54 PM
Do you really need red hash marks to know when its time to upshift?
Old June 21st, 2012, 10:01 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Yes. And a shift light.
Old June 21st, 2012, 10:34 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Honestly, id be nervous above 5 grand. These aren't the most durable engines.
-Jeff
Why? Step on the pedal till it hits the rev limiter I say...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old June 23rd, 2012, 06:57 PM
Feeding the kitten requires cutting a larger hole In the bulkhead ... And that's debatable as to it's effectiveness ...
Just call the useless heater a feature and move on to the next issue ..
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Help - 1994 D90 Purchase Questions - NC uzj100 Defender Technical Discussions 6 November 1st, 2005 01:31 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
PIAA 90 PRO XT (top) install questions... norros Defender Technical Discussions 22 June 30th, 2004 05:31 PM
Questions for a magazine chrisvonc Misc. Chit-Chat 11 December 3rd, 2003 02:42 PM
