Soft Top Vertical Bar Choices - Defender Source
Old April 16th, 2014, 07:46 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
Im installing a Bestop on my D90 project and came across an interesting problem. I have these vertical bars that hook over the horizontal bar over the door. However, in the AB install video for the top and in the Badger threads I have read they used a flat, approx 1 inch bar.
Does anyone have any experience with either and which do you prefer? It seems like the hook over/bolt down version would be more stable and keep out the rain, but this is an added PITA when swapping tops.
I have the hook over version but could easily fab up the others.
Lastly, does anyone have a better pic of the bottom of the hook over version installed? I pulled this one from another thread. Mine doesnt run flush with my tub and it looks like it'll scratch the paint up pretty good where it rubs. Maybe Im doing it wrong?? (insert that's what she said joke here)
Keith
...you'll feel better in a couple of days.
Old April 16th, 2014, 08:04 AM
User thehundredth just posted some good pics of them in his for sale post last week.
Old April 16th, 2014, 10:13 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
if you have a pocket in the flaps of the top then you have the 1997 version.
if you want to avoid scratches put a foam backing
the shape doesn't matter
good luck with your search
Old April 16th, 2014, 10:22 AM
CDeWan
Clay DeWan
5.3L beastie
The flat 1 inch bar is only used if the bottom of your top is sewn shut to act like a pouch for the bar. I run the 1 inch flat bar on my tickford and on my RoversNorth top. It braces the top between the tub and the upper snap rail but uses the tention created by the beltrail and upper snap rail to add the FDS rigidity behind the doors.
The bars that you are showing in the picture I am using on a best top I just bought and accomplish pretty much the same thing. I installed them just the same in the picture. I like Ron's idea of using foam under the foot to prevent scratching or possibly using a plastic washer to keep the foot from scratching up the paint.
Old April 16th, 2014, 12:48 PM
thehundredth
PJ
1995 D90 Beluga Black
The bars originally come with a foam strip on the bottom. Approx 1/4". That should do the trick.
soft top, top
WTB Soft top vertical bar tijnes Wanted 0 January 26th, 2014 07:29 AM
Soft top vertical bar tijnes For Sale - Parts 0 January 23rd, 2014 09:08 AM
Soft top vertical support rods/bars needed HeloBubba Wanted 10 January 13th, 2011 09:43 PM
Used D90 Parts For Sale - Badger Tops 3rd Brake Light Vertical Rods for Soft Top taoseno For Sale - Parts 12 June 28th, 2010 11:45 AM
Have a trashed Bestop soft top? Need tailgate clips, vertical rails, misc. jaherring Wanted 3 September 24th, 2004 09:15 PM
