Soft top third brake light is out. Now what. - Defender Source
Old December 20th, 2009, 10:39 PM
RickM
Rick Mabus
95 D-90 ST
Alright guys. I am being insanely lazy here because I have just spent about a week changing out just about everything in the fuel system of my f250 and I am exhausted.
My third brake light is not working and after taking it apart tonight I noticed it has 3 bulbs. I pulled the third bulb or passenger side bulb and it looked fine on first inspection but I did not check the others. I have also not checked with a volt meter if I am even getting power to the lines, but I plan to do that soon. So my first thought was to look at the diagram of the fuses hoping a fuse might be out and that diagram was not totally helpfull. I am assuming it is some sort of power issue as it would be strange for all three bulbs to go bad at once. That is unless we have some sort of christmas light style of wiring here. Anyone have a similar experiece to lend some wisdom? Anyone know if the fuse for the third brake light is different than the other two brakes?
Thanks everyone.
Old December 20th, 2009, 11:43 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
if it is the same as in the 97 look behind the passenger side rear speaker. there is a connection point that may be loose. as for the fuse I can't tell you.
good luck
Old December 21st, 2009, 08:36 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Have you tried reseating the bulbs? I've had them work loose in the past. Or ditch the third brake light and all the hardware that goes with it.
Jimmy Buffett
Old December 21st, 2009, 09:51 AM
RickM
Rick Mabus
95 D-90 ST
I am not sure legally in Texas I can ditch the tail light without being illegal. It is surely a piece of crap though.
Old December 21st, 2009, 10:48 AM
Connection is behond the speaker on the passenger side. There are two bullet type connectors (one power, one ground) I bet one worked loose if the bulbs are ok and the other brake lights work. It could also be the connection at the light itself which is internal to the light.
Ron
brake, ht, soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Best Top Soft Top For Sale WCURoverD90 For Sale - Parts 2 November 1st, 2005 04:24 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
top rear brake light and bar Marc Weinstein Wanted 2 March 11th, 2004 08:19 AM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
