Soft top rear door hinges... - Defender Source
Old July 31st, 2007, 02:24 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
My rear door is sagging, I have to lift it as I close it in order for it to latch. New badger going on soon so I want to get this door correct before installing the belt rail kit.
I put new hinge pins/balls/springs in but it didn't help much. I think the hinges are just worn from the weight of the spare and 13 years of use.
Anyone have a part # for these upper and lower hinges? Are they just series door hinges?
thanks
~Steve
Old July 31st, 2007, 04:30 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Just call George at Rovers Down South and tell him what you need.
Old July 31st, 2007, 04:58 PM
Grover's Avatar
Grover
Thumbs up
The hinges are cast iron and really should not wear, only the brass balls should wear out over time. Loosen the bolts that attach to the body, use a piece of wood as a wedge to lift the tailgate up and tighten the bolts. After adjusting mine, it opens and closes with ease. Also, I coated the brass balls with axle grease to minimize wear. Hope this helps!
Cheers...
Old August 1st, 2007, 01:20 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Mike, Ill give it a shot, hope you're right!
thanks
~Steve
Old August 1st, 2007, 03:09 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
There's a story somewhere on this site where a guy used Military hinges an fixed it right up. the hinges are flat metal which is probably a better design anyway.
Clay
Old August 8th, 2007, 11:25 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Well my hinges are definitely worn! But I was able to get the door closing correctly by loosening and moving the top hinge a bit..
now on to mounting the new top!
~Steve
door, rear door, soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Soft Top Rear Tire Carrier dannr09 Wanted 1 August 3rd, 2005 08:21 AM
White 95 D90 Soft top for sale.. sniff.. Richard Dekkard For Sale - Vehicles 5 December 1st, 2004 12:38 PM
