Soft top plastic windows - Defender Source
Old March 16th, 2005, 12:50 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I have on my D-90 soft top window some residue from clear packing tape. It has left behind a streak which I am not sure how to remove. I did a search and see that people have used stuff from Janvil.com who have a 3 part process and Maguires #18 clear plastic polish. My issue is not scratched, hazy plastic windows, but a non-sticky tape streak.
Ideas on how to remove it without trashing the plastic window?
Old March 16th, 2005, 01:01 PM
WD40 or Goo Gone.
Old March 16th, 2005, 02:00 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Years back I started using Pledge for regular cleaning of plastic windows. This cleans well without scratching, unlike a wash mit or sponge. The maguires does work well for removing scratches.
Unrelated, but for what its worth the goo gone worked real well in removing the old seal when I changed out my vents seals to Series III style.
"Uhh...I think they all leak like that."
Old March 16th, 2005, 02:03 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
If I can interject/hijack with a related question, without starting a new thread?
I did a search and couldn't believe I didn't find any info.
The other day I was digging around through my fastback top, parts to look for an answer for someone in a recent thread. When I unfolded the top there was a kink in the back window, when I straightened it out it cracked....Son of a .....!
Should I try Land Rover(bling)? Or maybe try an upholstery shop and see if they could sew in a new piece of plastic (something like the famous Art Vigil drop curtain window)?
any help would be greatly appreciated.
(sorry for hijacking paul, mom says hi )
Old March 16th, 2005, 02:08 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
A reputable restoration shop experienced in working with convertible tops should be of some help (Some places just do top replacement). Many times a new plastic window can be resewn in. Sort of like when Badger rebuilds the Tickford tops, new windows are installed.
Old March 18th, 2005, 12:30 AM
paulb's Avatar
paulb
Paul / Boultbee
Try an upolstery shop - or even a boat shop (lots of canvas tops with plastic windows on boats). I've a rear window off the full top I need to fix.
Old March 22nd, 2005, 12:30 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Or, if the crack isn't too large, you could just place your favorite sticker over it to keep it from spreading. Low tech, but works for me.
Old March 22nd, 2005, 01:22 PM
Rod Hayward
Rod Hayward
95 D90 Green #2288
Thumbs up
That's a damn good idea, Keith!
A d-90 Source sticker ought to fit about right.... Time to go to the Source store.
Rod
Old March 22nd, 2005, 08:58 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I had a trim shop quote $100 per window to replace and re-sow them in. That seemed a little on the pricey side to me, but the bottom line is that just about any upholstry shop (auto or boat) can handle window replacement.
soft top, window, windows
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Side Zip-out Windows from Soft Top gamberik For Sale - Parts 7 March 5th, 2005 09:59 PM
Soft top windows JBurt Wanted 2 November 14th, 2004 08:26 PM
FS: D-90 Soft top less windows dzientek For Sale - Parts 10 September 19th, 2004 01:02 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
