Soft top door line up - Defender Source
Old February 15th, 2005, 11:06 AM
cdy8
CD Young
I am considering purchasing the 97 below. Note the space between the door and soft top. Any idea on how hard/expensive this would be to fix?
Thanks!
Old February 15th, 2005, 11:25 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I use 2" foam pipe insulation.
$1.98 at Lowes
"It's not a Jeep"
Old February 15th, 2005, 11:47 AM
The pic is way to small to tell, but it can either be fixed cheap/free, or not at all.
I looks like the friggin support bar is either installed backwards or isnt there at all. I think people dont put them in sometimes if the top isnt warm and doesnt want to stretch.
I just cant understand how the gap can be that large, but a new top would fix the problem if the vinyl has just shrunk. You'd be amazed what a good sunny day will do though.
Old February 15th, 2005, 11:50 AM
cdy8
CD Young
Any idea how pricey it would be to a) replace the support bar? or b) get a new top? Am looking forward to going topless, but it still gets pretty chilly/rainy here in DC. Here is abetter picture.
Old February 15th, 2005, 11:53 AM
jabber
m j
110
When I get home, I'll try and post some pics of what I did to solve that issue. Basically, I went and got two pieces of aluminium bar stock (1/2" wide) and "bolted the softtop to it. Very effective and doesn't move! SUPER cheap too.
Old February 15th, 2005, 11:59 AM
The bar is probably under 50 bucks. A badger top (badgercoachworks.com) is the best choice and includes an improved arrangement for the door seal situation. OEM Bestops are almost 2000 bucks, and the Badger is a bit more.
Heres a pic, you cant see the bar because it runs through a loop/channel in the vinyl, but you can see that my truck doesnt have big gaps behind the door or a floppy top edge.
Maybe you tell the seller it needs a top and get him to come down a bit on the price. As you can see "they're all like that" is not a valid cop-out in this case.
Now I see your pic - that top is starting to rip and come apart. Its probably original and could really use to be replaced - like I said before - bargaining point.
BTW the waiting list for Badger tops is long. Shop early to avoid disappointment.
Old February 15th, 2005, 12:11 PM
cdy8
CD Young
Seems relatively low-priced $32k, only 38k miles.
Maybe that's the catch!
Old February 15th, 2005, 12:37 PM
JBurt's Avatar
JBurt
Jesse McCoy
That's not too bad (The top rip), especially going into Spring. Mine's way more F'ed up than that one and it was fine this winter. I switch to a surrey for spring to fall. Another option is the cab seperator that Badger or another guy on this site makes. If you're only running 2 people in it then it's great for the winter and summer (if you have AC). If it is a stock top I don't know that it'll get any better without a whole lot of work. Either way, if you like going topless then the door seal doesn't matter for most of the year.
"It's not a Jeep"
Old February 15th, 2005, 12:42 PM
Offer 30k and go buy a new top!
Old February 15th, 2005, 08:00 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'd be happy to take a look at the truck. I'm only 20 mins from Alexandria.
Jimmy Buffett
Old February 15th, 2005, 09:23 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I have the same gap - but on a 1994. Looking at the tech section here, someone has posted the instruction manual for the 1997 which, I thought, had a detachable post (i.e. thin metal strip) that went along the area where the gap is. Also, Yousef has a post on a door window frame he made - you got to hunt that one down with a search.
My 2 cents - $32k on a '97 where the top is not 100% bugger it! Some tops are just bad. Deduct a top from the sale, and I think $2k for a top is low (Badger with all trimmings is $2,800 I thought). Go to both vendors mentioned via the links on this site to check and do not forget the extras (window seals, capping, what ever).
door, soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Best Top Soft Top For Sale WCURoverD90 For Sale - Parts 2 November 1st, 2005 04:24 PM
White 95 D90 Soft top for sale.. sniff.. Richard Dekkard For Sale - Vehicles 5 December 1st, 2004 12:38 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
