Soft Top - Defender Source
Old November 29th, 2015, 05:26 PM
gilby's Avatar
gilby
1994 Defender 90
Soft Top
Winter's coming... Tickford just cloaked the '94. It's raining. I got wet...again. Amazing how 8-months running no top will make you forget.
It's been discussed before. What's the consensus on tops?
I don't like the look of badger gutter kits sans top. It takes away from the astthetics.
Best option for 'water tight' top (quotes because I know it's nonsense).
Thanks y'all.
Old November 29th, 2015, 05:35 PM
You can do the badger fabric door seals, or if you want it this winter, rovers north makes a nice top also with FDS.
Exmor is another possibility or oem bestop which you can get from RN or AB I believe. If you run that long w/o a top the extra 20 minutes to remove the gutter kit is pretty minor.
95' D90 - daily driver..
Old November 29th, 2015, 05:42 PM
gilby's Avatar
gilby
1994 Defender 90
I didn't realize the gutter kit was removable when running without a top. I'd think screwing into and out of aluminum over time would be troublesome.
Old November 29th, 2015, 06:07 PM
toona's Avatar
toona
Toona
1994 D90
Badger II FDS. The best.
Old November 29th, 2015, 06:29 PM
No not really - the bottom behind the door) screws into a Rivnut insert and the front part is a peg like arrangement - if i remember correctly. Mine is coming off for a hard top install soon so i'll have the parts to take pictures of.
anyway its a max 20 minute job
sounds like an FDS would suit you better
Old November 30th, 2015, 01:56 PM
gilby's Avatar
gilby
1994 Defender 90
Thanks for your thoughts. Cheers!
D-90 ex MOD soft top in great condition - AND - another complete soft top kit ZombieMotors For Sale - Parts 1 July 27th, 2013 03:23 PM
Badger Soft top - Proper Storage - Full Soft Tops and other tops rijosho Defender Technical Discussions 10 August 4th, 2010 12:31 PM
Soft top - Soft Doors? thelandroverguy Defender Technical Discussions 17 March 15th, 2006 04:24 PM
Fiberglass top for Soft Top? boshea Wanted 1 April 20th, 2004 04:53 PM
Fiberglass top for Soft Top? boshea For Sale - Parts 1 April 19th, 2004 04:23 PM
