soft top - Defender Source
Old July 23rd, 2010, 11:34 AM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
soft top
I have an 85 defender I need a play by play in properly removing the hard top. Is there a website or a post of pictures to lead me through this chain of events.
Old July 23rd, 2010, 11:45 AM
It is really self explanatory. Do you have interior trim on it?
Old July 24th, 2010, 04:55 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
1) remove roof trim (if fitted... pull off the rear view mirror, undo the 3 screws to release the mirror "bracket" thing, pull out the fir-tree fastners on the edge of the trim - above the doors.
2) with a 10mm spanner, undo the (6 i think) bolts along the top of the windscreen frame, they're bolted into captive nut things.
3) a couple of 10mm bolts on the top edge of the screen frame.
4) undo both seatbelt top bolts
5) brackets at the bottom of the roof panel.. there's a 13mm nut right where the door slam is, one in the back corner, and one at the edge of the rear door frame (mirrored both sides)
6) some have a small bracket mounted half way down the roof panel that bolts onto the rear tub capping.
7) remove rear end door (3 hinges at the side) and the door seal, oh, and the seals around the front doors
8) ring a couple of your buddies and get them to give you a hand to lift the whole thing off.
Old July 24th, 2010, 11:19 PM
8 is only if you are a weakling.
soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Best Top Soft Top For Sale WCURoverD90 For Sale - Parts 2 November 1st, 2005 04:24 PM
White 95 D90 Soft top for sale.. sniff.. Richard Dekkard For Sale - Vehicles 5 December 1st, 2004 12:38 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
