soft clutch...bleeding doesn't help? - Defender Source
Old June 26th, 2013, 10:54 PM
So I am madly trying to get my defender up and running, and one strange thing I am experiencing is that the clutch pedal is very, very soft. In fact, without the return spring, it might not have any pressure at all.
Bleeding the clutch seems to work fine - I bled the air out of the system, but still no firmness to the pedal, as if the slave cylinder is not pushing against the clutch fork. I don't know if that is truly what is happening, but that is what it feels like.
Anyone have any ideas?
------ Follow up post added June 26th, 2013 11:00 PM ------
Out of curiosity....free play on the master cylinder...could this be the issue? How much free play should there be?
Old June 26th, 2013, 11:20 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
You could have a bad master or slave cylinder. Easy to check. Clamp the rubber flex line between the slave cylinder and the hard point on the bulkhead. Then push down on the clutch pedal. If you have play it's most likely a bad master cylinder. If it's rock hard it's probably a bad slave cylinder. Both easy to replace.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old June 27th, 2013, 08:43 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Excellent Advice!!!
Also have found best results to change them in pairs.
Usually find when you install a new cylinder, the other one soon fails due to the extra performance and or requirements of the new cylinder. Happens more often when you change out the master and not the slave, but it also happens the other way around.
So again, for best results renew both cylinders together and installing a new hose won't hurt any, that's for sure.
RDavisinVA
Clutch bleeding woes tomaco1 Defender Technical Discussions 17 September 17th, 2011 10:48 AM
Slave clutch bleeding nikojo Defender Technical Discussions 12 April 26th, 2011 02:39 PM
Soft hose from clutch master tomaco1 Defender Technical Discussions 4 December 1st, 2009 01:07 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
