Soft Brake Pedal Issue.... - Defender Source
Old December 28th, 2007, 04:23 PM
greend90SW
DLJ
1995 D90 SW #367
I am experiencing a brake issue i am having difficulty running down. I am losing brake pressure after making any series of turns resulting in a soft pedal that goes approx. 1/3 to 1/2 way to the floorboard before getting any response from the brakes. The pedal responses normally on straightaway driving; ie no soft pedal, press=brakes, instead of press=wait for brakes (very unnerving).
I have dealt with almost the exact same problem before, which was loose front hub nuts, after replacing the front rotors. Pulled everything and retightened the hub nuts properly and issue was gone.
First thing i checked when this current brake problem arose was the hubs front and rear, all tight. My old land rover tech before i starting doing all the repair/maintenance myself suggested that the rubber brake lines at the swivel may have developed a bubble in the rubber causing a loss of pressure, checked those lines, all good.
I searched the forum and couldn't find anyone reporting a similar issue. I hope i have explained the problem well enough.
Any ideas guys? I am probably missing something simple.
DLJ
A bit of info i left out. I did replace the wheel bearings when i replaced the front rotors. When i pulled apart the front hubs to check for hub nut tightness i also checked the new bearings on the drivers side and they looked normal, no scoring or signs of wear (had about 20-30 miles on them). I thought they might have been damaged from the prior loose hub nuts.
1995 D90 SW
367/500
Old December 28th, 2007, 04:53 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
did you replace the bearing right, if you have a wobble in a wheel it pushes the pads back resulting in a few pumps of the pedal to get pressure
3rd low and BOOT IT
Old December 28th, 2007, 05:20 PM
greend90SW
DLJ
1995 D90 SW #367
The new bearings and races went back in the way the old ones came out.
Certainly i am aware that a wobble will push the pistons back and cause the need for double/triple pumps to push the pads back on the rotor, that was what was happening with the loose hub nuts after the rotors and bearings were replaced. I managed to diagnose and fix that instance of the soft pedal.
Thanks for the input Jimmy.
1995 D90 SW
367/500
Old December 29th, 2007, 02:25 AM
imola's Avatar
imola
did you bleed the brakes as well? maybe try to bleed them again.
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
» Defender Registry
110
RedRover02
Billy
Highseas
Add your Defender
