Soft brake pedal - Defender Source
Old April 20th, 2010, 02:40 PM
T.U.
Pete
94 D90
Question Soft brake pedal
While wheeling this past weekend, I had a couple of times where my brake pedal went soft after being started up. It came right back on the seccond pump. I checked the resivoir, no issue there.
Do I need to bleed out my brakes?
- Sorry if this issue has come up before, the site will not let my i-phone do a search.
Old April 20th, 2010, 03:30 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Was it ever soft after doing a lot of turns or going over a rough area? I have had this before and it is from the wheel bearings being a bit loose. Wheeling over rough terrain giggles the wheels/hub/rotors slightly (since they are all attached) and moves the brake pads out a bit. So that first press on the brake pushes the pads farther in to reach the rotors. This is why the second pump is normal. Check your wheel bearings for some play.
If this only happened when you first started the truck, then you may have some other problem.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 20th, 2010, 03:42 PM
T.U.
Pete
94 D90
Yes, is was during a very rocky segment of trail.
Thanks, I'll check the bearings out.
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Soft Brake Pedal Issue.... greend90SW Defender Technical Discussions 3 December 29th, 2007 02:25 AM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
