Soft Brake lines with a 2" lift - Defender Source
Old February 3rd, 2011, 11:08 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Do you need longer lines for a 2" lift on a 110?
Old February 3rd, 2011, 02:03 PM
NC Rover
Nick
1971 Series IIa Hybrid
I have a 2.5" lift on my Series 88...however I have a D90 galv frame w/ D90 axles, coils, brakes, etc. So basically a D90 with a Series body. I have the stock D90 brake lines and there is plenty of line left if it had to go higher. Eventually I will replace with the stainless lines...but for now the stocks are fine on a D90 setup w/ 2.5" lift. Not sure if this helps.
brake
2" OME Lift Before/After Pics pcscharfe Defender Technical Discussions 5 November 13th, 2007 02:09 PM
extended brake lines jimmy salmon Defender Technical Discussions 12 February 27th, 2006 11:07 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
