Soda Blasting - Defender Source
Old May 29th, 2013, 05:29 PM
Soda Blasting
I just dropped off the battle wagon off at the soda blasters. Here are a few before photo's:
Name:	photo 1 copy 2.JPG
ID:	73438   Click image for larger version
Name:	photo 2 copy 2.JPG
Name:	photo 3 copy.JPG
ID:	73440   Click image for larger version
Old May 29th, 2013, 05:31 PM
jafir's Avatar
jafir
Jafir Elkurd
For obvious reasons, I cannot wait to see the after pics. Are they going to blast it as it sits in the photos or is anything else coming off?
Old May 29th, 2013, 05:34 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
they doing the entire thing?
------ Follow up post added May 29th, 2013 05:34 PM ------
hahahah us ex MOD guys drool at this thought, I too cant wait to see man!
Old May 29th, 2013, 05:48 PM
Blasting as it sits. They are going to do it all minus the roof, rear x-member, tires & wheels.
Jafir,
Your truck was soda blasted and repainted in San Antonio. Your paint is peeling because they didn't neutralize the residual soda that embedded into the aluminum. After blasting it needs to be washed with soap & water, then etched with 50/50 vinegar and water or with self etching primer. I have done a ton of reading on this, I'll keep posting up on this project.
Old May 29th, 2013, 05:50 PM
jafir's Avatar
jafir
Jafir Elkurd
That explains a lot. Much of what I thought was Iraq coming out of the door handles is probably soda.
Old May 29th, 2013, 06:03 PM
I had excellent luck with glass bead blasting my truck. Tell the blaster to dial the pressure WAY down lower than normal. They should be able to remove the paint without removing the alodine, which is what my blasters did.
Otherwise - that looks great! Can't wait to see what you will do with the truck!
Old May 29th, 2013, 06:10 PM
jafir's Avatar
jafir
Jafir Elkurd
So if the alodine is removed will that also cause issues with the paint not wanting to stay put? Are all of the alloy panels coated with it?
Old May 29th, 2013, 06:12 PM
josh-man's Avatar
josh-man
joshua
whats a going rate for this out of curiosity? Jafir, do you mind sharing?
Old May 29th, 2013, 06:14 PM
jafir's Avatar
jafir
Jafir Elkurd
I'm curious about the same thing. I did find a place in town that does it. I'll have to call tomorrow.
Old May 29th, 2013, 06:16 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I had my last project acorn blasted for $175 an hour and it took 3 hours. Soda might be more not sure. Not sure if this is in the same ballpark!
Old May 29th, 2013, 06:21 PM
$120 an hour is what he is charging me.
Old May 29th, 2013, 06:50 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Way better then what mine cost! How many hours did they estimate?
Old May 29th, 2013, 06:56 PM
4 to 5 hours
I told him I wanted $500 worth of blasting, inside and out. Lets see.
Old May 29th, 2013, 11:03 PM
josh-man's Avatar
josh-man
joshua
Awesome.
Old May 30th, 2013, 01:20 PM
jafir's Avatar
jafir
Jafir Elkurd
I just called the place in town. They charge $100 per hour, and you also pay $35 per bag of soda, which they said lasts about an hour... so I guess about $135 per hour.
Old May 30th, 2013, 01:29 PM
Jafir,
Have you tried a power washer on your paint. It isn't very thick and the adhesion obviously isn't good. If you soda blast, it should be a pretty quick job. I have between 5 and 10 layers of paint, primer, etc....
Old May 30th, 2013, 01:51 PM
I can't tell if the adhesion is practically greater on the alodined panel, but alodine is technically superior to unpassivated aluminum.
Old May 30th, 2013, 07:41 PM
After:
Name:	photo 2 copy 3.JPG
ID:	73523   Click image for larger version
Name:	photo 3 copy 2.JPG
Name:	photo 4 copy.JPG
ID:	73525   Click image for larger version
Name:	photo 5 copy.JPG
Old May 30th, 2013, 07:42 PM
jafir's Avatar
jafir
Jafir Elkurd
Nice.
Old May 30th, 2013, 08:06 PM
josh-man's Avatar
josh-man
joshua
Awesome! Where are the doors??!!??
paint stripping, soda blasting
Media Blasting - NOVA area? Jonesy Defender Technical Discussions 11 March 25th, 2012 10:50 PM
Fair price for sand blasting? JimC and evilfij need help asap evilfij Misc. Chit-Chat 18 April 1st, 2009 02:15 PM
sand blasting and powder coating in colorado... TravelerBT Defender Technical Discussions 2 January 14th, 2009 06:32 PM
Sand Blasting / Acid Dipping a Bulkhead J.5 Defender Technical Discussions 0 March 19th, 2008 04:07 PM
Soda blasting ... Retrofit Defender Technical Discussions 3 May 29th, 2007 06:20 AM
