So the engine is toast where to go from here - Page 3 - Defender Source
Old December 3rd, 2012, 11:04 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by winn442 View Post
You can use a 4.0, there was a front cover called the "intermediate" cover that allowed the use of the newer block with the crank driven oil pump with a distributor. I think it was used only a year or so on the 4.2's.
On the cam, if you don't want to spend the money, you can use an aftermarket adjustable timing chain set designed for the 3.8 buick. (which I would use regardless over the factory timing set anyway, much more robust). Advancing the cam 3 degrees with the adjustable timing chain set will give you basically the same cam profile as a 4.6 cam or an aftermarket cam.
Winn the front cover you are referring to is found on the 1994-1995 Discovery (3.9) and the 1995 Range Rover Classic (3.9 and 4.2) were serpentine belt drive and had distributor ignition. Bill, that's why I mentioned the parts trucks I have. I have 4 complete 3.9 serpentine belt 14CUX engines in stock and I would LOVE to get rid of some of this stuff...
I like the rollmaster CS7000 timing chain but it requires a little clearance to work.
http://www.aulro.com/afvb/discovery-...ug-hole-4.html
Old December 3rd, 2012, 01:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Great link - lots of good clear pics of the Rover V8 internals including the crucifix seals and packing the oil pump with vasoline that has been mentioned on here a lot. Unreal how clean everything was.
That Rollmaster timing chain does look nice.
Old December 3rd, 2012, 02:48 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I like that link to that guy spent a good deal of time detailing the work, thanks Joel.
Unknown Author
716-898-8153
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
