snorkeling an NAS 300Tdi - Defender Source
Old July 8th, 2007, 09:04 PM
cdb
Clark Bowen
Has anyone found a good snorkel for a 300 Tdi that works on a converted NAS D90.
The clearance problem on the passenger side is the heater box and on the driver's side the brake system gets in the way.
I figure I could use the snorkel for the NAS D90 - V8, but I don't like how it runs across the top of the wing, covering the antenna, and hooks up to the wing vent.
Any ideas?
Clark
Old July 8th, 2007, 09:36 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
I used the nas v8 mantec snorkel on my tdi, I moved the aerial to the passenger side.
Old July 8th, 2007, 09:38 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The Mantec may be the one, check the site:
http://www.mantec.co.uk/store_ViewCa...D=1&Filter=All
Good luck
- Charles Eames
Old July 9th, 2007, 11:41 AM
Clark - I've got the NAS v8 snorkel on mine, but if you get the proper intake plumbing from George at RDS then you should be able to install the 300 snorkel. George had the plumbing parts last time I was down there, but you'll have to cut a hole in your fender...
Old July 9th, 2007, 12:12 PM
I recommend the over the wing type if you care more about function than form. The snorkels that come along the top of the wing are more protected from tight spaces and obstacle damage than the side types. that's what I have for my 2.8.
Old July 9th, 2007, 05:06 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
The southdown version works fine on the driver's side as well so long as you don't mind a little wing cutting.
Old July 9th, 2007, 07:55 PM
cdb
Clark Bowen
snorkeling an NAS 300 Tdi
Thanks everyone for the help.
I'll call George at RDS in the morning and google Southdown in the meantime.
Clark
Almost forgot....
Thanks David for the point about the side snorkels being vulnerable. Hadn't even though of that and I can put limb risers back on the D90 to protect the wing top mounted snorkel.
Clark
Old July 9th, 2007, 09:25 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Couple images here:
http://www.pbase.com/dmarchand/image...464/medium.jpg
http://www.pbase.com/dmarchand/image...467/medium.jpg
The routing of the hose works really well but some are adverse to cutting as I said.
Old July 9th, 2007, 11:09 PM
cdb
Clark Bowen
David,,,,,,,,,,,,,,
How did you route the hose inside the engine compartment? I've looked carefully at mine and it seems like the hose would crimp as you took it under the brake system and would then lay against the hose from the air-cleaner to the motor. Do you have any pictures that show your routing?
Clark
Old July 10th, 2007, 05:39 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Not really but I can take some later this week. Hose is routed under the master cylinder and passes underneath the air cleaner to engine hose, on top of the trans tunnel. Use a high quality, high temp hose and it won't crimp in any way.
Old July 10th, 2007, 09:23 PM
cdb
Clark Bowen
Called George at RDS today and he mentioned a problem with NAS 300 Tdi transplants: Water intake in heavy rain into the air cleaner unless you have a snorkel or the regular Tdi wing intake. The standard 300Tdi hose from the wing has a one way drain teeing off the hose midway to the aircleaner. This drains any water out before it gets to the aircleaner.
Unfortunately, I don't think the stock pieces will work because of the heater but it raised questions about DIY snorkel hoses - has anybody installed a one-way drain and if so what did you use.
Clark
Old July 10th, 2007, 09:32 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
There's one of those one-way drains in the bottom of carburetted 3.5 liter Range Rover air cleaner housings..
Old July 10th, 2007, 10:02 PM
same with the 300tdi air filter housing. that's what I use on my 2.8.
Old July 11th, 2007, 06:29 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Mantec "over the fender" V8 snorkle works fine, does not require any additional parts or cutting and only requires that the stock 300 Tdi filter housing be rotated to bring the intake port above the motor and the supply to turbo hose.
Matt Browne
Old July 11th, 2007, 06:39 PM
Cirbo's Avatar
Cirbo
Jim C.
Agree with Mark, and you will notice that the air filter canister is tilted so that the rubber valve is that the lowest point.
300tdi, nas, snorkel, tdi
My NAS to 300Tdi progress Gkase Misc. Chit-Chat 3 June 13th, 2006 11:11 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
few questions on fitting 300Tdi to NAS d90 Gkase Defender Technical Discussions 11 June 13th, 2006 03:17 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
