Snorkel (raised air intake) top? - Defender Source
Old November 21st, 2008, 11:45 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Hi. I'm looking to have a local muffler guy make me a snorkel while he's replacing my exhaust. However, I can't figure out where to buy a top for the snorkel (preferably in Canada). I've looked at donaldson.com and see these two PDFs:
http://www.donaldson.com/en/engine/s...ary/000207.pdf
http://www.donaldson.com/en/engine/s...ary/055471.pdf
However, I imagine that anything from there is going to be a lot more expensive, and maybe the wrong application, compared to a Mantec or Safari top. It's hard to know where to begin.
I have a 200tdi and the Donaldsons are rated for airflow; however, I don't know what my airflow needs are for a 200tdi.
If anyone has some help for me on where to get a top and what kind of top to get, I'd really appreciate it.
Thanks a lot,
- Andrew.
1986 110 CSW 200tdi (
Old November 21st, 2008, 11:56 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Calling Jack Walter to the white courtesy phone....
Old November 21st, 2008, 12:44 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Thanks for the cryptic and possibly useful, possibly useless response
I have done some calling around and found out that North Shore Offroad ( http://www.nsor.com ) can get me a Safari top for between $C96-112, which is I guess par for the course but also a lot of money for a little bit of plastic.
A friend of mine suggested just having the muffler shop bend the pipe forward and flare it a bit and not bother with buying a top. Is that a Bad Idea for any reason? I could just put a grille on it and be done with it, and could always buy another top down the road if I see someone selling a used one or something like that.
- Andrew.
Old November 21st, 2008, 12:59 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Hey !
Hi Andrew !
Glad to see you rig is back on the road. How was fixing that engine ? Was it badly damaged ? Hopefully I will get to see you this winter off road in some of the events.
Pat
Kirk Lazarus, Tropic Thunder
Old November 21st, 2008, 01:08 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Originally Posted by Retrofit
Hi Andrew !
Pat
Well my truck is "back on the road" in the sense that it's fixed, but I haven't picked it up yet from the mechanic's. It's getting a cat-back (in a manner of speaking) stainless exhaust system this afternoon and then hopefully I'll be driving it home.
I ended up sending it to a mechanic's shop about 6 weeks ago because it wasn't quite running and I didn't have the time or expertise to finish it off. My dad died and the truck was at his farm so I felt that I needed to move it, so I just spent more money than I wanted to spend having someone else do the work.
It's been off the road for 5 months so I almost forget even owning it It will be good to get it back. How's your vehicle coming along?
I'll talk to the muffler guys this afternoon and show them exactly what I want. Then I'll see whether they want to do the work and whether they're the right people to do it.
- Andrew.
Old November 21st, 2008, 01:24 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Andrew,
I have a spare Mantec mushroom top that I bought from SafariRover on here. If he does not have one for you currently, I'll sell ya my spare.
KB
Old November 21st, 2008, 01:32 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Originally Posted by KevinNY
Andrew,
KB
Hey, thanks a lot. I just found his contact info on the site and sent him an email. If you WANT to get rid of yours, let me know. Otherwise, if you'd rather keep it, I'll wait to hear back from SafariRover.
- Andrew.
Old November 21st, 2008, 05:59 PM
You could get a pre-cleaner. There are a variety of brands, but they do cost a bit.
The Southdown ram tops are indestructable and pretty cheap, http://stores.ebay.ca/Southdown-4x4-Products A friend just bought they two plastic pieces from Southdown and made the rest locally. Saves a lot of money and makes a very nice and strong snorkel.
If you are using a ram, then you want it separate as there are times it should be turned around.
Old November 21st, 2008, 09:35 PM
SafariRover has a mushroom top listed in his new shipment in the fleamarket sections (or was it vendor's loft?)
Old November 21st, 2008, 10:53 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I have a Centri brand pre-cleaner on the intake of my snorkel, It's an aluminum and stainless steel construction that is available in a wide range of intake tube diameters. I have one made for a 3" diameter snorkel tube since I was using some scrap C-130 fuel line tubing to build my snorkel. I think it cost me around $150.
Old November 22nd, 2008, 09:56 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
In addition to the Centri mentioned by Jack, http://www.centriprecleaner.com/, there's also:
http://www.sy-klone.com/
http://www.enginaire.com/
I'm sure there are others, but you can probably find local dealers of at least one of these in your area.
Check heavy equipment dealers, that's the most common type of dealer who carries them.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 26th, 2008, 08:16 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Use the PVC vent that lead out of the sewer line
http://images.google.tt/imgres?imgur...%3Den%26sa%3DN
air intake, snorkel
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Mantec Raised Air Intake Snorkle Top (NEW) roverboy For Sale - Parts 6 December 20th, 2006 09:19 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
