Snorkel Question - Defender Source
Old January 12th, 2009, 02:43 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Snorkel Question
i WAS WONDERING WHAT THE POINT OF A SNORKEL ON A GAS ENGINE IS BESIDES CLEANER DUST FREE AIR AND EYE CANDY. i MEAN, tHE INTAKE ON A DEFENDER OR A DISCOVERY IS ABOUT THE SAME HEIGHT AS THE DISTRIBUTOR SO WON'T THE ENGINE CRAP OUT IT THE CAP GETS WET REGARDLESS OF WHERE YOUR air intake is located???
sorry for all caps
This is where I'm supposed to write something witty and funny; or something.
Old January 12th, 2009, 02:51 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Yes a wet dizzy will end your trip through the river or mud hole but once the dizzy is dry the vehicle will start back up.
An engine that has ingested water is toast. Liquid does not compress so when the cylinder is full of water the water has nowhere to go during the compression stroke. End result is you need a new motor.
The wading issue is not the overriding reason to get a snorkle.
Dust free air and cooler air is the real reason. The air under the bonnet in the heat of summer is quite hot from the engine and the tarmac. That hot air will not carry as much fuel and your performance may suffer as a result.
If you have ever experienced buffalo dust then it does not take long to figure out that all of that particulate matter will not extend the life of your engine.
Old January 12th, 2009, 03:27 PM
JBOD77
Jonathan
okay but i at least I understand the wet distributor end of the deal.....is there many way to waterproof your distributor. I know that I can never have the same wading capability as a diesel but just looking to see what the real story is.
PS--I thought that a snorkel actually decreases performance, when I read what you wrote it sounds as thought the snorkel increases performance???? whats the skinny?
Old January 12th, 2009, 04:10 PM
landrovered
S. Smith
If the snorkle is designed properly and does not restrict airflow then it may enhance performance but in most cases the increase would be hard to notice. Engine longevity is more what it is about.
There are rubber boots that resemble a cows udder that can be used to help protect the dizzy from water ingress. Look on the brit parts houses websites for them.
One thing that you don't want to do is silicone your distributor cap to the base and gum up the works with a lot of sealant. This approach is a huge mistake.
If you are facing a particularly deep crossing, it may be prudent to remove the fan belt temporarily for the crossing. If you have electric fans in lieu of a vicous fan, then you can rig a switch to disable the fans for water crossings.
Proper wading technique i.e. creating a bow wave is the best defense against soaked electrics in the long run.
There is a good write up here on wading.
http://www.landroversonly.com/forums...ossings-15676/
Old January 13th, 2009, 08:43 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I used this when i had a distributer. lynchee has it now. It worked well.
http://www.wildhorses4x4.com/product...formance_Parts
Old January 13th, 2009, 09:06 AM
landrovered
S. Smith
here is another one.
http://www.mill-services-uk.co.uk/waterproof_kit.html
Old January 13th, 2009, 10:36 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
A trick I have used for years on my Series 3 88 is a rubber glove over the distibuter. Clip the tips off each of the fingers, feed the five wires through, a few tie wraps to seal it up and the cap is virtually water proof. I've had my truck into some fairly deep water and it hasn't missed a beat.
And like was mentioned earlier, it's all about the bow wave.
Brett
Name:	Duck in Gull Pond.JPG
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old January 14th, 2009, 08:56 AM
JBOD77
Jonathan
Ron,
When you got rid of your dizzy, what did you end up going with???
snorkel
snorkel question GeoParth Defender Technical Discussions 5 August 9th, 2005 07:53 PM
Yet another snorkel question gtg067i Defender Technical Discussions 4 June 30th, 2005 05:04 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Snorkel question searched and came up empty rustydefender Defender Technical Discussions 12 October 30th, 2004 05:43 AM
snorkel question Kerr Defender Technical Discussions 49 April 21st, 2004 12:08 PM
