Snorkel Install - Defender Source
Old December 31st, 2012, 06:14 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Snorkel Install
So I bought a snorkel from Brandon (dbj2003) and I got it today. Just a quick inspection immediately revealed that it mounts on the right side fender.
I have a RHD 300tdi truck but the square-ish hole with the grill on the fender skin is on the left side, none on the right side.
I don't know if sourcing a different fender skin with a hole and painting it will be cost-effective rather than just taking a dremmel to my existing fender. Obviously, measurements need to be as precise as possible if I go this route.
Also, I believe the snorkel is complete but I don't see any attachments to the air filter canister like on my D1 with the Mantec. Is that a separate kit or am I missing something? Anyone care to post pictures of their snorkel install under the hood?
Thanks and sorry for all the questions.
Glenn
Old December 31st, 2012, 06:43 PM
SURVEYOR
Dennis Saltys
97 D-90 LE #290
Th right side mount is usually for a 200 Tdi. Not sure if a 300 Tdi can be retrofitted for the RHS
Old December 31st, 2012, 06:44 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
What type of raised air intake? Post a pic.
I ran into a myriad of fitment issues when I swapped my hard tube type for a Mantec type when I needed to adjust for the A-pillar leg on the cage.
At least with the mantec unit, Just be aware that there are clearance issues with the fender well if you move that hole around (to the front).
Old December 31st, 2012, 06:45 PM
SURVEYOR
Dennis Saltys
97 D-90 LE #290
correction the LHS is usually for a 200 TDI
Old December 31st, 2012, 07:15 PM
Glenn_Guinto
Glenn Guinto
I'll take pics tomorrow when it's daytime. It looks to be a genuine LR part, (#PHD500340). Here's the for sale thread (pics towards the bottom)
http://www.defendersource.com/forum/...04&postcount=1
The snorkel box says 300tdi and my engine is a 300tdi. Since my truck has the left side grill, I'm guessing it was originally a 200tdi. It's an 85 ROW that had an engine conversion.
Glenn
Old December 31st, 2012, 09:10 PM
I think the right side fender mounts are for LHD trucks?
Old December 31st, 2012, 09:36 PM
dbj2003
Brandon Jones
94 Defender 90 POE
Glenn,
I bought it from another forum member for a LHD 110. That might be the issue. Perhaps the lower attachment could be swapped with one for a rhd truck? If it doesn't end up working for you let me know I can reimburse you and pass it along to next in line.
Sorry,
Brandon
Old December 31st, 2012, 09:51 PM
Glenn_Guinto
Glenn Guinto
Brandon, thanks! I'll keep that in mind... I'll try to see what my options are tomorrow and I'll let you know. If I can make it work, I'd rather keep it. Maybe I'll see if I can get a fender piece for a right side mount.
Thanks and Happy New Year everyone!!!
Glenn
snorkel
Airspeed defender snorkel install LRAIRSPEED For Sale - Parts 32 February 7th, 2013 04:25 PM
Mantec Snorkel and Custom Plenum Install Jackie Treehorn Smaller Projects 1 February 11th, 2012 03:44 PM
Mantec Snorkel - Clean Install? pcscharfe Defender Technical Discussions 12 September 15th, 2009 04:19 PM
Building my own snorkel - JackW Defender Technical Discussions 7 March 6th, 2006 01:39 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
