Snapped timing belt on Tdi - Defender Source
Old July 25th, 2012, 09:52 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Angry Snapped timing belt on Tdi
I think I broke my timing belt while running yesterday, engine just shut down, won't start again, no diesel going to injectors.
I'll get a check to see if valves are moving thru oil filler this morning, just to be sure, but I have that feeling that it snapped.
What other troubles I'm looking for ?
Cheers
- Charles Eames
Old July 25th, 2012, 10:07 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi julien, if it is the timing belt your looking at replacing some bent valves for sure, check them all carefully, its also common to snap or crack a rocker.
I've seen valves bent so bad they jammed in the guide, that timming belt let go at 3k rpm with a bang.!
let us know what you find, i hope it's not the injection pump thats died.
regards
Gren
Old July 25th, 2012, 10:55 AM
Whidbey's Avatar
Whidbey
86' 110
When my belt snapped it bent a handful of pushrods. That was the only significant damage. Your pump wont get fuel because it is not turning. I hope you don't have more damage. Good luck
Old July 25th, 2012, 07:04 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Just checked it and yep, timing belt for sure, rockers are not moving. Wrenching time !
Anyone knows a good webpage about this operation ?
- Charles Eames
Old July 25th, 2012, 09:38 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
http://www.landroverweb.com/landrove...200tdi-engine/
John Karlsson
Hope Valley, RI
Old July 25th, 2012, 09:55 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Pretty sure he has a TD5. Not sure the 200tdi link will work for him
Old July 25th, 2012, 10:14 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Td5's have timing chain not belt. Do not need to change like the 200/300 belts.
Land Rover 110
Old July 26th, 2012, 12:16 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Great write up, I have the 300 but the timing set up is quite the same I think.
- Charles Eames
Old July 26th, 2012, 09:45 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Oops just figured it was a td5 since it is an 05
Old July 26th, 2012, 01:27 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Yup, one of the last factory fitted Tdi, there is a fella in the Caribbean also, I think it's in St. Barth with an 06 Tdi.
- Charles Eames
Old July 29th, 2012, 11:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Did some work today, easier to wrench now.
ID:	54869   Click image for larger version
- Charles Eames
Old July 30th, 2012, 09:23 PM
discotdi
Todd Miller
Land Rover
How many miles since last belt change?
Old July 31st, 2012, 04:24 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Never changed. 75,000 kilometers.
I'd guess time broke it, 7 years of
daily use.
- Charles Eames
Old July 31st, 2012, 04:32 PM
You seem to be taking it well.
Old August 1st, 2012, 04:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I try hard.
Opened it this morning, belt not broken but missing plenty tooths.
- Charles Eames
Old August 1st, 2012, 04:51 PM
Defanged of its teeth? Yikes that's a new one. Sure as heck hope nothing seized on you and caused that to happen
Old August 1st, 2012, 05:56 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If I get a chance I'll pop it open tomorrow and see how bad is it inside head.
- Charles Eames
Old August 20th, 2012, 11:03 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
valves are ok, push rods are not.
- Charles Eames
Old August 20th, 2012, 11:27 AM
Boy if that's all that's messed up I would consider myself blessed.
Old August 20th, 2012, 12:38 PM
Whidbey's Avatar
Whidbey
86' 110
Also check the brass bits (I think they are called tappet guides but can't remember) below the push rods. I had one break. Nice to hear there was only minor damage. Oh, since the water pump is off, replace with new! Cheers
tdi
need 300 tdi timing belt crank shaft pulley andyrad Wanted 0 July 24th, 2010 02:11 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
300 Tdi Timing Belt roverboy For Sale - Parts 3 March 27th, 2007 09:06 AM
