Snapped timing belt on Tdi - Page 3 - Defender Source
Old October 14th, 2012, 07:05 PM
Damn that engine is clean! congrats. sounds great.
Mark Kellgren
KM4BOR
Old October 14th, 2012, 10:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sounds great! Running smoother than mine but I have yet to fine tune it. What's your idle set at?
Originally Posted by JFD
Finally getting somewhere:
http://youtu.be/SsuuYhec5n0
Old October 15th, 2012, 12:29 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
No clue on my idle.
Fine tuning ? where should we start ? let's do it.
- Charles Eames
Old October 15th, 2012, 08:58 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sounds like you've already adjusted it since you posted on the Advanced timing 300tdi thread. No need to fiddle with it anymore, runs like a champ if you ask me.
Idle should be set around 720 RPMs if I remember correctly. Sounds like yours is higher than that but i could be wrong. Get a laser tachometer and measure the crank shaft pulley.
No clue on my idle.
Old October 15th, 2012, 10:38 AM
how did you do that without the crank pulley in place?
Old October 15th, 2012, 10:48 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
No ancillaries belt. I ran a loop with a 3/8 clear hose on the oil cooler lines, filled the block with coolant and plugged engine coolant inlet and outlet. I did put the intercooler in place, don't want no dust inside my engine
Very short run, less than 30 seconds, but made me feel great.
------ Follow up post added October 15th, 2012 10:51 AM ------
Not at all, just the regular pins method. I do think we, Tdi users, should find a simple way to tweak the timing without buying special tools. I like the smaller pin method but we have to put some numbers on it imho.
------ Follow up post added October 15th, 2012 10:53 AM ------
Agree, sounds a little fast to me also. I think I have a tachometer connection on my Iskra alternator, time to spend some $ on a vdo unit I guess.
- Charles Eames
Old October 18th, 2012, 11:17 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My setup to put 11 p x f on the timing belt tensioner. According to comparison of this method with the click type torque wrench (distance between pulley and a fixed point in the line of pulley movement), the click wrench will lift the pulley 60 thousand of an inch more, about 1 mm and a half, I don't know how many pounds it represent.
- Charles Eames
Old October 18th, 2012, 11:53 AM
Shouldn't you use a bar type torque wrench? I didn't think it would work well with a click type.
Old October 18th, 2012, 12:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm not using the click torque wrench, I'm putting 11 pounds of weight at 1 foot distance. I did compare my results with the click torque wrench method and it's not quite accurate, even if you set it at lower value (did the comparison with wrench at 10 also).
- Charles Eames
Old October 18th, 2012, 01:37 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Once you do a few of them, you can judge the tension with your hand with just a plain socket bar on it.
Old October 19th, 2012, 02:04 PM
What i meant was, what was hiding the crankshaft timing belt pulley in place?
No ancillaries belt. .
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 19th, 2012, 03:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The crankshaft pulley bolt and big ass washer.
- Charles Eames
Old October 19th, 2012, 09:41 PM
Not trying to beat a dead horse but doesn't that leave like 2" or more of crank between the washer and the timing cog? And wormy the cog then be able to travel forward and back on the crank? I mean I know you only ran it for 30 seconds but I was concerned about that so I put the big pulley on. Even though it is kind of a hassle.
Present:
1987 RRC- "Chewy 2"
Past:
Old October 19th, 2012, 10:36 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Indeed, the crankshaft pulley was not under horizontal pressure, but no transversal movement as far as i know,
- Charles Eames
tdi
need 300 tdi timing belt crank shaft pulley andyrad Wanted 0 July 24th, 2010 02:11 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
300 Tdi Timing Belt roverboy For Sale - Parts 3 March 27th, 2007 09:06 AM
