Snapped timing belt on Tdi - Page 2 - Defender Source
Old September 4th, 2012, 04:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Starting to put it all back together, time consuming, 2 hours just to clean the block.
- Charles Eames
Old September 4th, 2012, 06:36 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
that is the exact same thing that happened to me. my timing belt never really snapped. but go like 45% of the teeth stripped off. and nothing else happened to my truck besides some light bents in my push rods nothing that bad! but goodluck!
Old September 4th, 2012, 07:36 PM
this thread has motivated me further to do mine ASAP!
Old September 4th, 2012, 07:51 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The "while I'm at it" syndrom is killing me, tomorrow I'm taking out the starter to clean it and grease it.
- Charles Eames
Old September 5th, 2012, 10:37 AM
looks great, julien
Old September 5th, 2012, 05:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
looks great, julien
Thanks Ed, I'll make continuous snaps of process.
- Charles Eames
Old September 11th, 2012, 03:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The WIH syndrom, fixing engine harness.
- Charles Eames
Old September 18th, 2012, 09:33 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Work in progress, end of this week i'm starting timing stuff
- Charles Eames
Old September 18th, 2012, 10:07 PM
Damn that's clean! Damn.
Old September 19th, 2012, 06:38 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Give it a week, it will look or normal again.
Semper Fi!
Old September 20th, 2012, 10:32 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Does anyone know if the crankshaft dust seal (ERR7143) comes out toward the front or the back of timing cover plate?
- Charles Eames
Old September 20th, 2012, 11:16 AM
Front.
Old September 20th, 2012, 11:40 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Thanks, I guess I can bolt the plate on and use a 2 legs extractor to pull it out, hmmmm...
- Charles Eames
Old September 20th, 2012, 12:01 PM
a normal seal puller wont work?
Old September 20th, 2012, 06:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Got it out, quite hard. Hope fitting the new one won't be a pita.
- Charles Eames
Old September 23rd, 2012, 07:39 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Does the alternator harness goes between thermostat housing and pumps bracket or on top of it ? can't remember how it was routed now..,
- Charles Eames
Old September 23rd, 2012, 08:17 PM
Naplm00
Matthew
On my defender motor it was in between
Old September 23rd, 2012, 10:17 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It's tight, but can be done. Small diameter convoluted sleeving, may be 3/8, can fit. It's kind of a shitty set up.
- Charles Eames
Old September 24th, 2012, 09:56 AM
Naplm00
Matthew
yes it is, I ended up putting on smaller connectors and wrapping it in the heat resistant fabric wire wrap tape that BMWs use.
This was i can disconnect it and yank it through if needed
Old October 14th, 2012, 07:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Finally getting somewhere:
http://youtu.be/SsuuYhec5n0
- Charles Eames
tdi
need 300 tdi timing belt crank shaft pulley andyrad Wanted 0 July 24th, 2010 02:11 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
300 Tdi Timing Belt roverboy For Sale - Parts 3 March 27th, 2007 09:06 AM
