snapped bolt - Defender Source
Old July 2nd, 2007, 06:33 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
snapped bolt
Iv'e been driving with 4 bolts holding the rear half shaft. Now its started leaking grease. went to undo the bolts and snapped 2 more. Never drilled out a bolt before, is there a tool to get it out.
3rd low and BOOT IT
Old July 2nd, 2007, 08:01 AM
Cirbo's Avatar
Cirbo
Jim C.
It's really wierd on those hubs. Both times I've encountered snapped bolts, they've come out very easily. I don't fully understand how a bolt will snap, but the broken piece almost turns out by hand.
jC
Old July 2nd, 2007, 09:29 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Easy outs might help:
http://www.toolprice.com/category/sc....jumboeasyout/
Old July 2nd, 2007, 09:30 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I've snapped about half of mine on the 94. Get a good drill, really good quality drill bits and "easy out" kit. The easy kit will resemble a drill bit box but the "bits" are fatter and reversed threaded to grip inside the hole you will drill.
Start with a smaller drill bit and drill a pilot hole in the center. The work the hole open a little more, the try the easy-outs. Here are some directions on using one:
http://www.crustyquinns.com/tech/easyout.html
Chris von C
[/size]
Old July 2nd, 2007, 10:58 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
How are you guys breaking 1/2 shaft bolts? You're not driving them in with an impact gun are you? I would have to check, but I think that the torque on those bolts is 50ftlbs--I can't imagine breaking one with such little force.
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Bolt attachment for a Southdown steering guard paulb Defender Technical Discussions 3 January 20th, 2005 08:42 PM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
