snap crackle pop and . . . a tow - Defender Source
Old June 28th, 2014, 11:39 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
Stopped at a red light today, green light and I release the clutch. Rig doesn't move, as if the brakes are applied. I forgot the exact sequence of things I did (jiggle transfer case, gun the engine a bit) but I manage to get the rig moving again at around 30-40mph. But rough rumbling noise coming from front end, so I get a tow. At home I jack up one of the front corners and turn the wheels by hand. Front drive shafts making rough noises as I rotate wheel. Front differential seems ok, will drain tomorrow to see if any metal shards come out.
So, the correct diagnosis is bad u-joints/front drive shaft? Should I replace just the u-joints or entire front shaft assembly? Replace rear drive shaft assembly too, as a precaution? Rig has high mileage, I'm not the first owner.
Could the bad front shafts have resulted from a bad transfer case? Vehicle can still move around, but with rough noises from front end. Or vise versa, can bad u-joints/drive shafts damage other components?
How do I test the front transfer case? I was thinking of up jacking up all four wheels, engaging diff lock and either turning wheels by hand or running engine.
Old June 29th, 2014, 12:42 AM
Sounds like a broken CV joint. Does it run fine (but with noises) if you lock the diff?
Old June 29th, 2014, 07:45 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Idk, but if you jack all four wheels you might not get the same result given they are not under load. I chased a DS issue for a while and learned it sounded differently when under load. Drive me nuts.
Clay
ac, rack
Dixon-Bate- Rare Tow Jaw with 2mm (1 7/8) tow ball USED NashvilleRover For Sale - Parts 0 December 19th, 2011 11:24 AM
tow bar to match safari gard bumper tow points? Raleigh D90 Wanted 1 April 28th, 2011 11:50 AM
Disco II Driver window pop JohnsD90 Defender Technical Discussions 6 July 9th, 2009 06:39 PM
POP under my left foot when I hit the gas. wicks Defender Technical Discussions 11 September 30th, 2008 09:30 AM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
