Snap and a belt rail top - Defender Source
Old April 25th, 2012, 03:22 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Curious if you can run a Tickford top (with snaps) and a belt rail set up on the same truck, can you have snaps and rails installed or do they conflict?
Old April 25th, 2012, 03:29 PM
people have had snaps installed on the belt rail.
Old April 25th, 2012, 03:44 PM
I have heard this said, but when I look at this I failed to see how you could put the snaps on the belt rail and have the top fit properly. You'd effectively raise the snaps in order to mount them without interfering with the belt rail and the top would be too loose.
Originally Posted by pendy
I'm here for the D's
Old April 25th, 2012, 07:23 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I have snaps and the belt rail (always assumed the previous owner addred the rail). Never tried it but as the snaps are below the belt rail, do not see it to be an issue. The profile of the belt rail is low so space should not be an issue
I'm contemplating thinking about thinking about it!
Old April 25th, 2012, 09:33 PM
Interesting. I'll try dig up a rail tomorrow and take a picture of it on mine relative to the snaps. IIRC my snaps are higher.
Old April 26th, 2012, 10:09 AM
So perhaps my truck is different from others, but this is what I have. I'd have to move my snaps up and I think my tickford would be loose. If I moved the rail down it would be too low for a bestop/badger and look goofy to boot.
ID:	50804 Click image for larger version
ID:	50805 Click image for larger version
Old April 26th, 2012, 10:45 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Attachment 50804 Attachment 50805 Attachment 50806
2x Yours is the same as mine.
