Smoking...more - 2.5NA - Defender Source
Old November 27th, 2015, 10:05 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Carrie and are driving our '86 Ex-MoD 90 from Houston to San Francisco. We are taking our time to sight see and make stops. And not taking the interstate for the most part. Saw Ship Rock, took some passes, went trough Bryce Canyon National Park. Made it to Reno yesterday.
So, in the 35,000 miles we've driven (of the 57,000 on the odometer) it has been 'smoke free' while driving and looking at the tailpipe in the mirror. In the past at elevations above 3,000' I have noticed more smoke than at lower elevations.
But this time it seems to be putting out more smoke at all times under load. Color? Dark, black or blue?
Plus it just doesn't seem to have quite the power I'm accustomed to. (Yes, Okay, it's a 2.5NA. It's not a powerhouse.)
Also, for the first time I'm operating in colder weather than I've driven it in before. When it's below 20 in the morning, it is VERY hard to start. I believe the glow plugs are working because the heater fan slows down a lot when I turn the key to the glow plug position.
My question: Am I developing a problem? Is there something I should be looking for? Or is this just what to expect from a 2.5NA at high elevation in the cold?
I understand that I should not use 'starting fluid' in a diesel. Is there something else that I could use to help it start on cold mornings?
Old November 27th, 2015, 10:14 PM
It's over fueling from the altitude. A friend just had this same issue a few weeks back. Once you are back at sea level it will be back to normal. You engine hates cold and altitude. 20-30 seconds of glow should work. How long are you preheating for?
Congrats on finishing the type school.
Old November 27th, 2015, 10:17 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Q. "Is there something I should be looking for?"
A. A 200/300Tdi.
Old November 27th, 2015, 10:24 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I've been holding the glow plugs on for 10 to 15 seconds then crank. I don't crank too long and repeat. It took 5 or 6 of these cycles to start this morning.
------ Follow up post added November 28th, 2015 01:26 PM ------
A. A 200/300Tdi.
A wise man once said:
"If I had to explain, you wouldn't understand. Now go away."
Old November 27th, 2015, 10:27 PM
Turn the fan off and give it a bit longer. Like I said these motors hate cold and altitude. Don't use any starter fluid no matter what.
Old November 27th, 2015, 10:28 PM
These engines like a lot of glow. Give it more than that. At 20 I would be 30 seconds. A minute at zero.
You may also not have proper winter diesel in there. Add a good dose of a winter diesel fuel conditioner.
Old November 27th, 2015, 11:10 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Okay, more glow plug time. A couple of the recent gas stations have had "winter diesel" signs posted. I'll buy a can of something at O'Reilly's tomorrow.
Old November 27th, 2015, 11:18 PM
Chowbird's Avatar
Chowbird
Tim
'84 D90
Mike,
Guam, Houston, San Fran?...Gotta be UAL. Always glad to see fellow "co-workers" 😄
I'm EWR 756...about to be ORD. Have a great and safe trip. Tim
1984 D90 LHD 3.5 V8
2010 Range Rover Sport
Old November 27th, 2015, 11:35 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Originally Posted by Chowbird View Post
Mike,
Yes, you figured it out. Just finished 787 simulator training in Houston and moving my airport car (Defender) to SFO. My first working flight is LAX to Shanghai on Wednesday.
EWR to ORD?
Old November 28th, 2015, 09:52 AM
Chowbird's Avatar
Chowbird
Tim
'84 D90
Excellent!! Congrats. I'll PM you. Don't want the thread to stray. Hopefully she'll pop back to normal as you head for sea level. Have a great trip (Defender and 787). Tim
1984 D90 LHD 3.5 V8
200tdi low on power and smoking Sun Traveler Defender Technical Discussions 32 June 10th, 2014 06:59 AM
Defender 300TDI smoking graham Defender Technical Discussions 5 May 24th, 2013 10:02 AM
smoking exhaust d90 SBrick Defender Technical Discussions 3 January 16th, 2012 05:21 PM
smoking deal on a Howling Moon 1.4 RTT Uncle Douglas The Flea Market 0 July 15th, 2011 10:19 AM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
