smoking like James. bond. - Page 2 - Defender Source
Old September 3rd, 2014, 09:04 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I've had a few decks skimmed and a pressure test was always the first step. Thought this was standard procedure at any machine shop. It takes a few minutes to blank the water outlets and pressurize the head at 40psi.
Old September 3rd, 2014, 09:23 AM
The original poster says the head he bought was checked and pressure tested.
His issue is smoke and down on power after over heating and replacing the head and injectors. Since the injection pump hasn't been touched, timing not touched. I'm betting compression is way down
Old September 3rd, 2014, 11:38 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Someone had mentioned rings. I second that motion.
Black Rhino Lives Matter
Old September 5th, 2014, 05:32 PM
bkgonefishin
brent
85 110 w/200tdi
Well I bought an adapter for my compression gauge and did not realize that the gauge is insufficient. It only goes to 300 psi and the first cylinder burried the needle somewhere around 350. I will have to get an appropriate gauge. I also checked to see if there was any pressure coming out of the dipstick tube when the engine was reved and no there was not. I replaced the oil breather/separator just in case my cleaning was not good enough. The trucks power seems to be better from the rebuilt injectors.
It is still smoking smoking in the morning but I have a theory about what's going on. I think the turbo is so shot that its leaking oil into the intake. That oil is what is smoking when it's cold. This is also why there is oil in the pipe that goes to the intercooler. Am I way out there with this thought? Isn't this how diesel engines run away?
Oh, and I found a leak in my radiator and had one sent from paddockspares. Installed it today and coolant level seems to be good now.
Old September 5th, 2014, 05:56 PM
it's possible. could be center section seal or bushings. grab the compressor wheel with your fingertips and wiggle to check for play. any noticeable play and you found a problem.
Old September 5th, 2014, 05:58 PM
bkgonefishin
brent
85 110 w/200tdi
Yea there is play left and right and front and back. Lots of play
Old September 5th, 2014, 06:13 PM
the rover shop
shayne young
If you have oil in your intake pipe... Then yes, the turbo cassette is no good..
Roof rack ffrom defender in james bond 'Skyfall' l*factor Defender Technical Discussions 6 July 17th, 2014 08:07 AM
James Bond's Defender Double Cab Surf90 Misc. Chit-Chat 4 November 9th, 2012 07:48 AM
James Bond Skyfall 110 dcpu Ben01 The Flea Market 0 October 24th, 2012 11:10 AM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
Range Stormer the next Bond car? boshea Misc. Chit-Chat 2 March 25th, 2004 01:53 AM
