Smokey exhaust - Defender Source
Old July 30th, 2006, 05:25 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Smokey exhaust
My '95 smokes. Sometimes it is a little and sometimes ALOT. It is definately oil burning off, due t the smell. It normally happens as I am going down a hill either coasting, or really badly when I use the engine for compression braking.
So my question is why? I hypothize that it is a ring going. What do you guys believe.
I got your JEEP thing, now it hurts when I pee!!
Old August 2nd, 2006, 08:55 PM
Mine does it too, I think it's the exhaust valves sticking or something like that. I have been told that you can squirt some water in the air intake under WOT at full load and it will break up any build up on the valves and keep them from sticking. But I have not tried it as of yet, and I have just tried to not use any compression braking lately.
Old August 3rd, 2006, 09:49 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Ya, I have been told it is a bad valve seat (possibly gunked up), causing suction to pull oil up into the Cyl. I have some AMSOIL cleaner I will try soon to see what it does. I can't imagine it is in bad shape as the truck only has 60K on it.
Old August 4th, 2006, 01:20 PM
So we are in the same boat, my 90 runs great (well most of the time) other then the exhaust. I ran some Seafoam through the intake and it seemed to help. I think I might try it again and at the same time do an Italian tune up!
Old August 4th, 2006, 02:02 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I tried sea foam for my first time about 2 months ago. I was warned that it would smoke/smell, but I assure you I had no idea how much! Next time I use it, I am going to do it at night when my neighbors can't tell.....
Old August 7th, 2006, 03:48 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
May I ask what an "Italian tune up" is? Revv the engine past 10K? ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 8th, 2006, 10:38 AM
LOL!!! I love that part! for even more smoke try driving around the block!
More or less, take it up to 5k under full throttle. I am not sure how the V8 would do at 10,000 RPM though.
Old August 10th, 2006, 06:23 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
make sure your flame trap, "T - peice" and etc are all clean and functional as that sometimes will over pressurise the system and get you a little smokey when off the pedal.
Matt Browne
exhaust
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
