Smaller NAS 110 water pump pulley - Defender Source
Old July 11th, 2014, 09:07 PM
mattm's Avatar
mattm
Matthias Moran
1963 109
I just got back from a trip where I towed about 6000Lbs of trailer over the mountains in over 100 degree temperatures. Perhaps not surprisingly, overheating was a bit of a problem.
I've done nearly everything that I can think of to keep it cool including installing a thicker core radiator. I'm thinking that a smaller water pump pulley might help by running the water pump and cooling fan faster. Does anyone know anything about this and where might I be able to source a smaller pulley ?
Old July 11th, 2014, 09:33 PM
What about putting the a/c condensor fan on a switch that would allow you to turn on a pusher fan when needed ?
Old July 12th, 2014, 02:51 AM
mattm's Avatar
mattm
Matthias Moran
1963 109
Good idea except that in that kind of heat, the a/c is on anyway and even if it wasn't, there's a coolant temperature sensor in a NAS 110 which turns the a/c fans on when the coolant temp rises and mine is working (I checked.)
Also, I believe that even large electric fans (I upgraded mine) are relatively ineffective compared to a viscous coupling fan.
110, nas, nas 110, pulley, water, water pump
300tdi water pump pulley Michael Wanted 5 May 30th, 2014 10:47 AM
Water pump tension pulley Surf90 Defender Technical Discussions 19 February 5th, 2013 01:09 PM
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
3.9 water pump pulley ZACHASS Wanted 1 December 2nd, 2008 09:25 AM
smaller tires scout x Defender Technical Discussions 3 March 14th, 2006 11:51 AM
