small start up issue - Defender Source
Old September 6th, 2015, 11:58 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hello Board-
Recently I have noticed when I go to start the 95 NAS 90, completely stock, after it initially starts, RPM's will drop down to almost nil, then catch and run perfectly normally.
It doesn't do it every time and the truck is rarely driven so I want to get ahead of any issue.
Could it be as simple as running a can of BG?
Not really a big deal just noticed it over the last few months. It never dies, just RPM's just drop then catch almost immediately.
Anyway, Happy Labor Day!
KCD
Attributed to Shayne...
Old September 6th, 2015, 02:09 PM
Originally Posted by kevincdoyle View Post
Hello Board- Recently I have noticed when I go to start the 95 NAS 90, completely stock, after it initially starts, RPM's will drop down to almost nil, then catch and run perfectly normally. It doesn't do it every time and the truck is rarely driven so I want to get ahead of any issue. Could it be as simple as running a can of BG? Not really a big deal just noticed it over the last few months. It never dies, just RPM's just drop then catch almost immediately. Anyway, Happy Labor Day! KCD
Air idle control valve or an air leak in a hose. My guess would be the big hose has started to rot unless it's been changed.
Old September 6th, 2015, 10:38 PM
kevincdoyle
Kevin C. Doyle
Thanks Jason. I've seen a few references to the AICV and the hose is new.
I will check out the valve.
KCD
Old September 6th, 2015, 10:58 PM
Thanks Jason. I've seen a few references to the AICV and the hose is new. I will check out the valve. KCD
Just make sure you don't replace that hose with something that isn't 100% original!!
Old September 7th, 2015, 09:06 AM
kevincdoyle
Kevin C. Doyle
Hah!
Never going to happen!
But I will research cleaning air idler valve and run a can of BG through first!
Thanks guys!
Old October 9th, 2015, 09:18 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Kevin where did you get the air intake hose (big hose)? I can't seem to find them anywhere? I have determined mine has a leak and has been the bane of my existence.
Old October 9th, 2015, 09:50 PM
kevincdoyle
Kevin C. Doyle
William, mine was new. There is a thread here somewhere about new ones. I'm hopeful Josh will chime in and show us the way..
Old October 10th, 2015, 09:19 AM
wmatos1001's Avatar
wmatos1001
William
Thanks, I ended up replacing the AICV versus cleaning but oddly mine was extremely easy to unscrew off. I practically could have done it by hand. But I definitely have a weak / rotted part of the big air hose that looks to be where unmonitored air is getting in and causing lean burn, odd idle (generally high) and occasional stall.
Amp and ignition coil all have been replaced and I'm getting code / check engine light #48.
start
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
95' RRC No Start Issue Wolf Fabrication Defender Technical Discussions 16 November 2nd, 2012 02:39 PM
Gauges and Start Up Issue Defender_90 Defender Technical Discussions 2 April 13th, 2012 12:06 PM
89 Rover Classic no-start issue (not my own) Hans Defender Technical Discussions 7 March 28th, 2007 09:42 PM
