Small electrical fire in my 90 - Defender Source
Old February 12th, 2015, 01:04 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Last Saturday I had a small electrical fire and a melted corner of my fuze box. It left me stranded because there was no power going to my fuel pump. So now a friend and I are chasing the problem.
Since my dash is all apart I decided to take out my air con unit since I never use it. And I also want to relocate my ecu. I really want to move my ecu to my tuffy box.
Is there an ECU relocation kit that I can or have someone make? And does anyone know where I can find a Diagnostic module (the code reader box). Mine looks like it is falling apart!
Old February 12th, 2015, 01:10 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
My fuze box
Old February 12th, 2015, 01:11 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
ID:	113586 Some of the wires are burnt some were just starting to melt.
And a ground wire was melted back to one of the relays about 7 inch long bare ground wire.
Old February 12th, 2015, 06:41 AM
Hm, looks expensive. The wire that shorted will be burned all the way, not just where you can see. That means that you will have to run a whole new wire to replace it.
You'll also need a new fuse box, and new relay holder and relay where the one failed. There is a special tool that pops the connectors out of the fuse box and relay holder. It is available from Autosparks.co.uk, or from britishwiring.com.
Old February 12th, 2015, 07:57 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You can find that fusebox replacement on Ebay UK or Rovers North.
They do not make an extension for the harness for you. At least non that I could find anyplace when I looked. I did extend a GEMS harness to get the computer under the Pass. seat on a 110 I am building. You will need to get a another harness to get the correct gauge wires and colors if you do extend it. You will also have to be pretty knowledgeable with electronics however as you need to be careful with the data lines resistance.
Old February 12th, 2015, 01:31 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
You are so lucky. That could have turned out a lot worse.
Rule numero Uno. Always carry a fire extinguisher on board. Never carried one until I got a Rover.
Black Rhino Lives Matter
Old February 12th, 2015, 08:56 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Bill-
I found the fusebox but not sure on the special tool.
http://www.autosparks.co.uk/product_...oducts_id=1272
What is the tool called? Is it the terminal extraction tool?
http://www.autosparks.co.uk/product_...oducts_id=5252
Old February 12th, 2015, 11:15 PM
Grover's Avatar
Grover
What caused the fire?
Old February 13th, 2015, 12:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
George at RDS has the fuse rebuild in stock. Personally, I'd toss him the business.
http://www.rdsparts.com
Just go to Defender, Electrical. You'll see it.
Old February 14th, 2015, 02:42 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Looks like it was from a bad ground that rubbed against the bulkhead.
I called him first. But I didn't think of mentioning the fuse rebuild.
Small Car Advice Flagg Misc. Chit-Chat 6 January 13th, 2010 09:18 AM
Small parts WhiteD90 Wanted 4 January 19th, 2005 01:00 PM
sw small rear windows mattdh Defender Technical Discussions 1 July 5th, 2004 05:05 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
galv. small parts mattdh Defender Technical Discussions 0 November 20th, 2003 08:31 PM
» Defender Registry
Shaun
StuartL
GRNWOLF
GRNWOLF
Add your Defender
